Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Guesses on ET?
Old Feb 2, 2003 | 07:57 PM
Z28Clone's Avatar
Guesses on ET?
I have a 327 block bored 20 over, 350 crank, 882 heads milled to 70 cc, 4.10 gears, 600 cfm carb, T5 trans in a 91 RS. Im gonna run it this spring. What kind of ET will it have ? This same motor was in a 65 OLDS 442 w/ 3.08 gears, (heavy car and same heads had 78 CC at the time) and ran 15.3 with a TH400.
Old Feb 2, 2003 | 08:13 PM
BillZ28's Avatar
Car: 84 Z28
What kind of cam or any horsepower numbers?
I'm guessing mid to hi 14's.
Old Feb 3, 2003 | 05:08 AM
Z28Clone's Avatar
Thats it? its a summit Street/strip cam, i dont have #'s on it. no dyno info either. i should pick up at least a 1.5 with the 4.10, get more with milled heads, then get even more with a lighter car.
Old Feb 3, 2003 | 07:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you don't like the answer then wait until the track opens and go and see exactly what it will do. A guess is just a guess. No 2 cars are identical so no one will know exactly what your will do without hard data.
How much does the car weigh?
How much dyno rear wheel HP does it have?
Give me that data and I'll tell you what the car should run. Other than that, it's all a guess.
Old Feb 8, 2003 | 10:42 AM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
Agreed...
BC
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
