Harness mounting points?
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
When putting in a 5 pt. harness do you use the factory seat belt anchor points for the lap belts? Also what is required to attach the submarine belt to the floor?
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
mine are mounted to the stock seat bolts, the submarine is mounted through a 1/16" plate and the floorpan underneat the seat, and the shoulder points are anchored to the rollcage
Car: 1986 Iroc
Thanks for your quick reply. I should weld a 6" X 6" 1/16 plate to the floor for the submarine and then bolt the tab to it correct?
FWIW -
https://www.thirdgen.org/techbb2/sho...hlight=harness
Here's what I did. While the description and pictures in this thread are my 4th gen, I lifted this setup directly from my old 3rd gen.
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
