Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First 1/4 mile run w/Z28-- help me analyze the results
Old Apr 6, 2003 | 05:02 PM
91 Camaro Z28's Avatar
Hey people- first time at the strip this afternoon and got some dissappointing numbers, but definitely a starting point- My camera sucks so i'll just type in all the vital information-
What can be done to better these times-
What is considered a good time for a stock Z28 with 2.73s?
I'd like to break into the 15s with my car the way it is- how can I do it?
The Altitude:
5800' above Sea Level
The Car:
1991 Camaro Z28
305 TPI 98,000miles
T-5 Tranny
2.73s
K&Ns
Ram Air Mod from Tech Articles
The Slips:
#1 Run
Reaction Time:---.755
60ft:-------------2.571
1/8th Mile:-------10.662
1/4 Mile:--------16.414
MPH:------------ 86.743
#2 Run
Reaction Time:---.666
60ft:-------------2.506
1/8th Mile:-------10.861
1/4 Mile:--------16.650
MPH:------------ 85.226
#3 Run
60ft:-------------2.596
1/8th Mile:-------10.706
1/4 Mile:--------16.467
MPH:------------ 85.854
#4 Run
Reaction Time:---.611
60ft:-------------2.785
1/8th Mile:-------11.001
1/4 Mile:--------16.852
MPH:------------ 85.209
Old Apr 6, 2003 | 05:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Start with some good tires or some slicks. The poor 60' times are killing your ET. You should be able to get them down to at least low 2.x. Once the 60' times get better, the ET will also.
It's possible that the track is too slippery also. Find out what other racers were doing at the same time. A regular racer with a real race car would know if the traction was good or not.
Old Apr 6, 2003 | 06:14 PM
when i race-- i drop the clutch at about 3 grand and the car almost dies-- its like the clutch is slipping real bad- i have to hold the clutch in for like the first 2 or 3 seconds, otherwise i'll almost stall- could that be a sign of a bad throwout bearing or something? its a Centerforce Dual Friction clutch so i dont know what the problem is.
The track seemed ok because some people were gettings low 2's and some 1.8, 1.6s even saw a 1.5:hail:
Is 16.4 a time to be expected at my altitude and stock setup?
Old Apr 6, 2003 | 07:26 PM
MdFormula350's Avatar
yeah those 60 foots are killing you alot.
Old Apr 6, 2003 | 08:06 PM
what about the MPH--86 and 85 seems a little low-
any suggestions to lower my 60' time?
Old Apr 6, 2003 | 10:02 PM
well good tires is a must, i would think with decent street tires and the stock z28 suspension you should be able to pull 2.1 or at least 2.2 60 foots..
practice helps alot also, i have an automatic, i would guess its alittle harder when launching with a clutch.
Old Apr 6, 2003 | 10:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That mph should give you high 15's. Maybe a very low 16. You have the hp to run 15's from the mph but don't have the traction.
My 454SS truck on a bad day usually runs 15.7's at 87 mph. At 15.0 it was almost 90 mph.
Old Apr 7, 2003 | 12:45 AM
does it sound like i have a clutch problem based on the previous post?
Old Apr 7, 2003 | 10:52 AM
Also, i forgot to mention that i was running at 220 degrees on all the runs- how much power am I losing running that hot-
will i pick up any tenths running at 180?
Old Apr 7, 2003 | 11:47 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
sounds like you need a good tuneup, your mph seems pretty low, next time out, def. work on your 60' and ice your intake, when was the last time the plugs/wires/cap/rotor etc were changed? I dunno that just seems like a low mph for a 91z..when my motor was bone stock i was trapping 88-89
Old Apr 7, 2003 | 12:22 PM
thanks for the replies-- you guys rock- i'm gonna be doing a tune-up in the next couple of days-
plugs
wires
cap
rotor
fuel filter
PCV valve
ignition coil
how do i check the idle air control sensor and the throttle position sensor?
someone also recommended checking the TPS voltage? how do i do that and what should it be?
Old Apr 7, 2003 | 03:59 PM
Coqpit's Avatar
Car: Black '91 Z28
Engine: Bone Stock L98
That track must have been really slippery or something... My car gives me consistent 1.9x 60ft times... and i also have a 91 Z28 with stock suspension and street tires... although i do have the l98 with the auto so maybe you just need some more practice on te launch... and I thought te 91's with the 305tpi/5 speed got the 3.42's????
Old Apr 7, 2003 | 05:04 PM
my car was originally auto- i threw the 5 speed in myself-
can anyone comment on the clutch problem i'm having?
Old Apr 7, 2003 | 05:08 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
how good of a driver are you?
Old Apr 7, 2003 | 05:40 PM
i think i'm a good driver- every car i've ever owned with the exception of my first one has been stick so i can drive well
Old Apr 7, 2003 | 05:52 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
what are you doing when you launch? are you dumping it at 8972349rpm or riding the clutch? how many miles does the clutch have on it?
Old Apr 7, 2003 | 06:04 PM
i tried dropping at various rpms everything from 1200-5000
i tried riding the clutch out, and i tried just letting it go, but when i do that, it wants to stall..
the clutch was bought from a guy on here who said it had like 5000 miles on it.
centerforce dual friction
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
