Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
tires for the strip
Old May 11, 2003 | 04:46 PM
chainbearer's Avatar
tires for the strip
ok, I have 15's on the rear of my car now with 75 sidewalls. I plan to put the original size(16) on the car. with 50 sides. which os better for traction and drag strips? I plan to use street tires.
I thought I could keep the 15's to use at the strip and use the 16's on the street, but I'm not sure if I will get better times with the 16's or not.
also should I get a body mount kit if I want to drag alot? My mounts are soft *** original rubber.
Old May 11, 2003 | 06:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Keep the 16's with some street tires and get some slicks for the 15's. You'll have a much better selection with 15" rims.
You're not going to get better times because of the rim size. The 15" rim is just more popular. It also gives a little more sidewall which is needed for drag racing. 16+ rims have little sidewall and are designed for cornering. With a small sidewall, the tire won't roll over in corners and will stay on the pavement better.
Body mount kit? Third gens are unibody. Everything is spot welded together.
Old May 12, 2003 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think he means suspension bushings. Poly bushings are a good improvement over stock rubber. But, not a cure-all. Boxed lower control arms & track arm also help.
Sub-frame connectors are a good idea to improve general body stiffness.
F-body-fan
Sep 17, 2015 12:16 PM
Nick McCardle
Sep 10, 2015 08:36 PM
fasteddi
Sep 10, 2015 09:32 AM
Amillionoh7
Sep 5, 2015 11:44 PM
