Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
gear ratio
Old Jul 12, 2003 | 08:39 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
gear ratio
My car is still equipped with the stock 2.73 gear ratio. Is that a horrible ratio? It's probably not good for racing, huh?
Old Jul 12, 2003 | 09:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's a highway gear to keep the engine rpms low at highway speeds. A performance street/strip gear would be 3.42 or 3.73. 4.10 gears and deeper are usually a bit too much unless you use 28"+ tall tires.
Old Jul 13, 2003 | 05:04 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Yep. Ideally you want to be at the top of your 1:1 gear (3rd in most automatic cars) through the traps, 2.73's wont even put you at the top of second in most cars. A friend of mine with a stock 350 in a 73 Nova went from 15.5's to 14.2's from swapping from 3.08 gears to 3.73 gears, posi and msd .
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
