Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New Best
Old Oct 4, 2003 | 04:34 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
New Best
Trying out a new chip and it worked! It finally got me back into the 1.6x launches. Haven't been there since I was still on the stock stuff. It doesn't pull near as hard in 3rd gear as the Thrasher chip I had before. Best MPH before was 121, best with this chip was 117.7. Either way, I'm happy Just need to combine the good of both chips to make a really nice run.
Here's the run:
60'.........1.623
330'.......4.755
660'.......7.420
MPH.......90.69
1000'.....9.706
1/4.......11.618
MPH......115.77
Old Oct 4, 2003 | 04:59 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
What rear end, gear ratio and converter are you running?
Miles
Old Oct 4, 2003 | 05:36 PM
TTA 1387's Avatar
Stock rear. 9 bolt, 3.27 gears. 245/50/16 Nitto DR
3200 Vigilante
Rob
Old Oct 4, 2003 | 07:37 PM
MdFormula350's Avatar
badass :hail:
Old Oct 5, 2003 | 08:10 AM
TTA 1387's Avatar
Originally posted by MdFormula350
badass :hail:
Thanks, still trying to get kicked out of the track. Hasn't happened...yet
Old Oct 5, 2003 | 01:18 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
hey man congrads on your new best.nice car!..i was out there on saturday too for the EFA shootout.i was driving my buds 01ss..i got second place in the ET bracket racing. .i was gonna try to chat with ya but couldnt catch up to ya..
Old Oct 5, 2003 | 02:45 PM
TTA 1387's Avatar
Lots of nice cars, that's for sure. How about that 3rd gen Formula running 9.4's. Impressive. And the other TTA running 10.4 but blew a head gasket about 100' from the traps.
Great time as usual. I got bumped in the 2nd round, spun too much coming out. Its ashame because I was all over that tree yesterday. That doesn't happen very often
Maybe we can hook up sometime.
Rob
Old Oct 5, 2003 | 08:56 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Nice times!! I have a few more questions on the rear though as I've been running a 9 bolt behind my big block for 5 years now.
How many passes on it?
Ever though of going to a 3.73, 3.91 or 4.10 gear?
I'm curious how that would affect your 60ft. I went from a 3.27 to a 3.73 and my 60 ft was the same at 1.72-1.75, but I'm only running a 2400 converter and I definately need more. I'm thinking about going to the 3.91, but without an overdrive (ie T400) and 26in tires, that's a lot of rpm on the highway
Do you like the 3200 vigilante on the street? With that much stall and only a 3.27 gear, don't you get a lot of slippage on the highway (especially in OD)?
Miles
Old Oct 6, 2003 | 12:50 PM
TTA 1387's Avatar
Have probably close to 200 passes on it.
With the 245/50/16 Nitto Drag Radials, 3.27 is all the gear I need. I'm going through the traps at 5100 or so. Any higher and I would have to go into OD. That's with it locked up also.
As for the short times, it might help but the turbo Buicks really don't need gearing to launch. Just stall and boost.
I love the Vig on the street, at the track, anywhere. Once it locks up in 4th, its just like stock. Still get over 25mpg, 20-22mpg combined. I think its a great converter, pricey but you get what you pay for.
Old Oct 6, 2003 | 02:18 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
Awsome times. You're really getting the power to the ground! ( especially w\ drag radials )
Old Oct 9, 2003 | 12:13 AM
C-ya pony's Avatar
Car: 91 z28
Engine: 408,t-ram,twisted wedge aluminum heads
I'm new here, hope you don't mind if i ask. Do you have an oppinion on the nitto tires vs. drag radials. whats your elevation? Here i'm at 4000 ft it sucks my 91 z28 is running 12.70,s - 12.90's on the gtek.
Old Oct 9, 2003 | 08:49 AM
TTA 1387's Avatar
The Nittos I have are drag radials. I use them as every day tires. They are getting a little thin for street driving. They have about 13K miles on them right now.
But I did do a comparison of BFGDR vs Nittos on my 96 WS6. I ran 315/40/17 BFGDRs vs. 275/40/17 Nittos. Best 60' on the BFGs was 1.80. Best on the Nittos was 1.75. Mileage for the BFGs was 6K. Mileage for the Nittos was 15K.
Car was a 6spd with 4.10 gears. Best run was 12.4@111.
My opinion is the Nittos are better. They last longer and are more consistent. The BFGs are terrible in the rain. The Nittos are fine for everything but snow That's why I bought them for the TTA.
Hope that helps
Old Oct 9, 2003 | 03:24 PM
AllGoNoShow's Avatar
I have 275 Nittos DRs on my car with a 5-speed TKO manual...any tips on getting the launch right? Might doesn't hook too well yet.
What tire pressure do you use, and what is your burnout technique and how long do you hold it for? Thanks for answer my qeustions a head of time.
Old Oct 9, 2003 | 08:42 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Very nice times especially with DR's!
Old Oct 9, 2003 | 09:33 PM
TTA 1387's Avatar
16" I run 20-22psi. 17" I ran 17psi.
With the WS6, I never could dump the clutch. Even with ET Streets and a 5500 dump was still the same 60' as the Nittos.
What I did was a 2nd gear burnout for about 4-5 seconds until you could see smoke in the mirrors. I used to bring it up to about 4-4500 and dump the clutch. Just modulate the gas/brake to not over rev or stall the engine. Take foot off the brake and let the tires bring the engine down. Roll up to the line and get ready. I brought the rpm up to about 15-1800 depending on how the pad was. I would launch with rolling on the throttle as fast as I could at the same time letting the clutch out. Not really riding it but coming off fast. Think of it as fast feet I never just mashed the pedal.
What really helped me was practicing launching on the street. Its really a finese kind of thing. Once you can get it on the street, do the same thing at the track and modify the rpm to where you don't bog or spin. Just takes practice.
And if you want to make up some time during the run, never lift. That's worth .3-.5 sec. by itself.
Old Oct 10, 2003 | 10:10 AM
Thanks for the tips!
I have to try this never lift thing, I'm a little scared tho I will have to get a rev. Limiter first! I can see how it wouldn't be that hard for the 1-2 or 3-4 shift but how do you not lift for the 2-3 shift that is pretty damn long.
Old Oct 10, 2003 | 11:36 AM
TTA 1387's Avatar
Try it at lower rpm so you don't over rev if you miss. 3rd isn't too bad once you get the hang of it. I used the palm of my hand and pushed diagonally. The shifter is 3rd gear biased and should go right in. If you actually try and shift it, you'll miss it.
Its also easier with an aftermarket shifter.
Rob
Old Oct 10, 2003 | 12:57 PM
Ringmaster72's Avatar
Car: 1989 IROC
Rob, when u had the WS6, what were your 60' times? I also have a 6 speed with 4.10 gears and was curious what i will be able to pull once I get some traction.
thanks
Tim
Old Oct 10, 2003 | 03:25 PM
TTA 1387's Avatar
thanks
Tim
With the stock GSC's, the best was a 1.87 with most in the low 1.9 range. With the Nittos, 1.75 was the best. Many 1.7 short times the last year I had it.
Rob
