Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/8 mph
Old Dec 15, 2003 | 12:12 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
1/8 mph
i have a 358 with a 268xe cam, dart pro1s[200cc],rpm intake ,650dp, 3.42 gears, th350 tci 3000 stall, 2055 headers and a dnyo max 2.5 catback. my runs about 82mphs in the 1/8. it seems like it it sound have a little better mph . right? i know that the 2.5 exaust is is hurting it.
Old Dec 15, 2003 | 02:28 PM
muggsyjack's Avatar
Car: 1992 RS Camaro bracket car
Transmission: TH-350
We have run a best of 8.11 @ 85+ in 1/8 mile. Are you spinning tires a lot? What is your 60' times?
You should see more MPH IMO unless you are spinning way too much. You have enough cubic inches to build speed. We are only running a 305, granted with slicks and 4.10 posi. Our 60' is at 1.85. We are in process of changing cam and manifold to drop 60' further. We have no traction issue, just not enough torque.
Old Dec 15, 2003 | 03:19 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
That trap should put you around 102-104 in the 1/4!
Old Dec 15, 2003 | 05:01 PM
Car: 89 camaro
Engine: 383
it pulls about 2.10 60ft on street tires. i ran it once in the 1/4 it ran a 13.87 @101 also on street tires
Old Dec 15, 2003 | 05:03 PM
Car: 89 camaro
Engine: 383
you think the 2 1/2 catback could cause a 3-4 mph lost?
Old Dec 16, 2003 | 08:26 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
I think that you would unleash many ponies if you did a cam swap. Your current cam is a little on the small side, considering the large intake runner size of the heads you have. I would suggest something with a duration of at least 230 @ .050" and close to .500 lift. You might consider stepping up to a 750cfm carb also. And yes, that 2 1/2" exhaust is most likely hurting performance. 3" would be much better.
Old Dec 17, 2003 | 12:23 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Also carb is too small, 750 or an 800 would be much better. I'm running 86/ 87 mph with the GTA in sig. But the car is slow, 8.80s to 8.90s. I don't think much of the xe268 for a race cam. I'm going to try a 305h next spring, but I don't intend on driving it every day like I did.
Old Dec 19, 2003 | 10:43 PM
chad89ta's Avatar
keep the carb i run dart iron egale heads with 215 cc intake runners and rpm intake comp cam extreme 274 230 236 @.50 488 lift 490 im going to try the 294 comp and victor jr intake, with that set up i run 8.2 at 90 in the 1/8,if your not turning 6500+the 650 is fine
Old Dec 19, 2003 | 10:47 PM
chad89ta's Avatar
try jetting the carb to 69 82 that should help,i got 71 84's in mine
Old Dec 21, 2003 | 04:21 PM
Car: 89 camaro
Engine: 383
right now i have 69 76 jets i have'nt played with the jetting much i'll try that. thanks
Old Dec 23, 2003 | 04:03 PM
chad89ta's Avatar
jeting can make a big diffance i nocked off a full sec of my ets,from when the jets that where in it i think they where 67 74
Old Dec 23, 2003 | 05:18 PM
Car: 89 camaro
Engine: 383
i just puts some 80s in, man it feels alot better. i thougth i had 76 in the back but they were 75. i might try some 82s like you said.
Old Dec 28, 2003 | 07:03 PM
chad89ta's Avatar
well the setup you got is a good one,you might even try 71 84,or just keep playing with it till its right,those dart pro1s are bad *** heads, with good flow,i would bump up to a victor jr and 284 or 294 extrem comp cam,i just put the victor jr on and the 294 cam it and whent to the track and my best et was 7.6 at 96 with 1.90 60 ft time on street tires,with the heads you got and the 294 cam you should trap at least 96 mph,but you already have a good runner,just tune it in
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
