Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Serious fuel systems.....
Old Jan 7, 2004 | 09:29 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
guys that have serious fuel systems to feed their power plant....
what are you using for a pump/bypass/regulator combo?
and are you running a seperate nitrous fuel system, or branching off your main feed?
im re-doin the fuel now, and there are so many pumps and regulators from so many companies, all rated in different units with different size inlets and outlets its hard to get a bead on what you really need
Old Jan 7, 2004 | 10:25 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
stock tank sumped for 2 -10an fittings 10an to a aeromotive filter, a aeromotive pump , 10 an to the front of car to a aeromotive return style regulator, and 10 an return line, 8an from regulator into 950 carb. NOS system ; 3 gallon fuel cell mounted in left front corner. 8an to aeromotive filter , to holley blue pump, holley regulator, one side t's to fuel press. gauge and restricted return to cell , other side 8an to a 8an to 2 6an Y, 6an lines to both fuel solnoids. everything is stainless also. i think that covers it
mike
Old Jan 7, 2004 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
4 gallon cell mounted in the front, BG280 pump, Holley Volumax regulator, Fleetguard FS1212 filter. -10 lines from the fuel cell to the carb.
Old Jan 8, 2004 | 05:38 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Magnaflow Pro Star 500 with built in fuel filter and external fuel return. Also using their 4 port regulator. Same set-up many of the pro-stock guys use, and will support up to 2,000 horsepower. -12 lines from tank sump to pump, -8 from pump to regulator, 3/8" OD stainless steel hard lines from regulator to carbs. 36 psi going in to regulator, and 6 psi going out to the carbs. Way overkill for my current engine combination, but plenty of room to grow - and very reliable.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
