Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Tc?
Old Jun 21, 2004 | 07:45 AM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
Tc?
I was just wondering if it would be a good idea to get a torque converter with my set up. If so what stall? I was thinking of putting a 2400 in but I'm not really sure if this is something I should do? are there any disadvantages with going to a higher stall?
Old Jun 21, 2004 | 04:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A higher stall converter will allow the engine to quickly reach it's higher power band. Anything is better than stock. The stall speed should match the camshaft and diff gearing.
Disadvantage is that since the engine will operate at a higher rpm more, fuel economy will decrease.
Old Jun 29, 2004 | 02:38 AM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Don't forget the added tranny heat. Make sure you run a tranny cooler if you install a higher stall.
