burnout........
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
burnout........
What household type product can stop the rubber from the BFG`s sticking to the quaters and wheelwells? Just wondering if anyone has something they use to prevent the long clean up time after several burnouts? I was thinking of using some sort of agent that would stop the rubber from sticking or make it easy to remove, what should I use?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
PAM cooking spray too.
Thanks for all the replies guys! Yea, I went to the track and didn`t use anything, in a rush as always and realized, as I was pulling into the gates, that I had forgotten to bring Anything
Well, went thru the burnout box several times with 30-50 second burnouts and guess what?? the rubber just brushed right off the quarters with my hand! No wonder I couldn`t hook the thing worth a darn
Last set of BFG`s I had i had to use a solvent to get burnout rubber off the panels, maybe it was the tires , maybe the track?
Last set of BFG`s I had i had to use a solvent to get burnout rubber off the panels, maybe it was the tires , maybe the track? Joined: Mar 2000
Transmission: 4L80E/4L80E
The reason you couldn't hook was "30-50 second burnouts". That's about 25-45 seconds too long.
I have tried different lengths and speeds at which to heat the BFG`s, this was my third set now. This set seemed to be longest wearing pair I`ve had but they have never gone in the 1.6`s like the last pair I had. (actually 1.70 best to date with these) I have made ALOT of changes to the car (for traction and power) but basically I can blow the tires off the car at will. The last set I had were on the last ride and I decide to john force`em at the box, I had third gear at 7,000 for at least 25-30 seconds...rubber was on the hood even! Funny thing was that the car pulled a 1.67 and went 11.90`s...this is after being in the 12.0-12.20 area with 1.8`s to 2.0 60`s all day. Wierd I thought but now I`m just thinking freak. I have passed the point of BFG`s truly bogging the car at the light, the car just won`t hit`em that hard, so M/T`s are next for me.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
this car right here runs 11.90's all day long on a 275/60 bfg tire/stock style suspension without any spining problems, does about a 10 second burnout...granted, it's a foot brake car, but look at the tire wrinkle
this car right here runs 8.60's all day long on a 325/60 bfg tire/stock style suspension without any spining problems, about a 15 second burnout.
alot of your problems may be with track prep, but i can garuantee it's more to do with suspension setup, make sure your pinion angle is set right and stuff ( I want to say that -1* is a good starting point) my point: these tires work and i have many other pics of different cars launching just as hard or harder...
I know there are many cars capable running many seconds faster than me on BFG`s....I would like to "wrinkle" the side walls, but with a 255 50 16 there just isn`t much sidewall to wrinkle @ 16psi.
I agree with you about the suspension, it`s all new and I have not had a lot of time with it at the track, the torque arm is a spohn chrome moly with the rod ends, I had it all over the place, all the way to -6*, which did hit the tires hard but vibrated so bad I couldn`t run the 1/4. The vibes are better at -1*, but the traction is poor.
I have the relocators for the lower control arms on the bottom hole. To me these have not made a difference at all, but hopefully they will shine once everything is working together
The lower control arms, I have swapped those out too... tubular slp`s with poly bushings...I felt a difference instantly. the car lifts much more even in the front and rides a little stiffer in the rear. I also did a poly bushing panhard too.
There is one thing bothering me with the suspension right now, when I brake torque it, the car rear raises up about 3-4 inches, this all started with the new t/a from spohn, The car used to "squat" when brake torqued....For some reason, maybe the really heavy front wieght I have, the car left the line better when it would squat.
Track prep was bad prior to me being there, I had talked to a few a z28.com that said "that`s the last 20.00 they`ll get from me".
I`ll be trying Milian next...I will at least have something to compare these last runs too. here is a picture of it lifting the rear
Theoretically, lifting the rear is a good thing. In order for the rear of the car to go up, it has to be pushing down on something - asssumed to be the rear axle. Pushing down on the axle means more force to provide traction at the tire/track contact.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What the? The black car looks cool but it's got hubcaps on the rims! Unless the hubcaps are screwed on, they're supposed to be taken off or it won't pass tech.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
hey monkey, what size cowl hood is that? Bolt or lift off?
looks sharp
mmm...cowl hood:hail:
Brandon
looks sharp
Brandon
What track did you go to greeze?
Engine: 7.0L
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
With a big block's inherent high amount of torque, plus the torque multiplication of your 700r4's low first gear, it's IMO that you are just plain overpowering those small tires (all the chassis tuning in the world won't fix it). If you have a 3.73 or higher numerical rear end ratio, you should probably consider a shallower gear, if you really want to use those tires with your combo. Personally, I'd strongly consider getting a TH400 trans which would be better suited for your application (shallower first gear, much stronger). Don't expect Milan's traction to be any better (especially on a non-race day), and you certainly won't be able to make near as many runs. Also, unlike Ubly, as soon as you hit 11's at Milan with your car, you better have ALL the necessary equipment, or else you'll be making only half-track passes.
255 width, 50 series, 30 second burnouts - all contributing to failure.
255 - too narrow.
50 series - sidewall too short.
Long burnout - more smoke, higher temp, no additional benefit.
I'm not going as fast as you guys, but you don't have to do something necessarily to know if it's the right thing or not. When I ran DR's, I asked BFG about burnout technique. Their response: Don't do a burnout. Just turn the tires enough to clean them. The traction is in the compound.
Of course, we out in the real world know more about their product than they do...
255 - too narrow.
Some things you can do to counter act and let it work for you..
Softer rear springs making it harder to raise rear.
Adjustable rebound shocks to slow that effect.
Lower car to allow more travel.
Try leaving not on converter so hard to allow tire to plant, You rear is raised so high you lost the mechanical advantage of the TQ arm to benifit you.
Here is a pic launching and one just sitting.
http://www.pittsburghracewaypark.com...m=101&pid=6591
http://www.team3rdgen.com/modules.ph...view_photo.php
Thanks, sounds like some good advise...I do have adjustable rear shocks but the extension length is too long..I think they are for a 67-69 camaro,(possibly not allowing full travel ?) anyways I was under the car later that week and did noitce that the passenger rear shock was leaking oil
I had them set for "most bite" the instructions listed this as 50/50 but with one gushing oil I`m sure this is why it would lift so easily.
About the rear springs, they "were" stockers for a 85 Z but I had put an extra spacer in them years ago, I have switched to the moog cargo`s but removed all of the spacers..so it`s a lot lower now but still raises up when tourqed.
going to lower the front for next year, also going to 90/10 and new elcheapo shocks in the rear
I had them set for "most bite" the instructions listed this as 50/50 but with one gushing oil I`m sure this is why it would lift so easily.About the rear springs, they "were" stockers for a 85 Z but I had put an extra spacer in them years ago, I have switched to the moog cargo`s but removed all of the spacers..so it`s a lot lower now but still raises up when tourqed.
