u joints and drag racing
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Has anyone that is running slicks or even drag radials in the low 13's had problems with the factory u joints holding up ? I just do not want any surprises because it is fairly inexpensive to have more heavy duty u joints installed. Vehicle specs; 90 GTA, 5.7, built 700r4 w/2800 stall (shifts hard as I requested to the builder)3:23 gears. Probably 50 1/4 mile passes in stock form running low 14's. Just installed Crane Powermax cam, headers, rollertip rockers, AFPR, true double roller timing chain and gears. I have not run it yet with mods. I will probably be lucky to be pushing 300 h.p., should I be concerned with the u joints? I will be racing it often and with slicks.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I raced for 2 seasons, everyweekend at any track that had an event with countless passes and I never had trouble with the u-joints...it was always the rear ends (4) that blew out for some reason??
Was only running 1.70-1.78 60's back then, but I think as long as your current U-joints are in good shape, the General (GM) has the safety factor built into the ring gear so it will implode before anything else does LOL.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
At 300 hp and an automatic transmission, I wouldn't worry about the factory u-joints. If they're worn they will fail but if they're in good condition, other parts will fail first.
I use 1350 series u-joints but mainly because I also launch with a transbrake.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I agree with IHI and Stephen, I ran two seasons in my old TTA on the stock steel driveshaft, u-joints, and rear for that matter - consistant 11.9-12.0 car at 113mph with a best 60ft on 1.63
I now run a 3" moly shaft w/1350 joints after I had a stock style alum shaft fail(ripped in two actually)in the mid 11's w/60fts in the high 1.5's
HTH,
Steve
HTH,
Steve
sjorgens
Oct 1, 2015 07:54 PM
