Made it to the 11's
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Made it to the 11's
The car finally made it to the 11's with an 11.863 @ 113.281 with a 1.67 60ft.
Then 2 runs later the engine went South. So far I know the lifters on 7 and 8 are smashed badly and the back of the cam is broken and loose. I would suspect a rod let loose.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Been there. Done that. Engines always run the best just before something lets go.
Car: 1986 Iroc
Number 8 rod broke about 1 to 1.5 inches above the throw. Smashed the cam up and broke out the back of the block around the cam bearing. Found a valve head, oil ring, and other smaller bits in the pan. Looks like not much to salvage.
Car: 1986 Iroc
Posted what I thought happened before we tore it down. Rod didn't break the number 8 piston disintegrated. That caused all the carnage.
Car: 1986 Iroc
Never had the motor or car on a dyno so don't know what hp it had.
90/10 drag struts on the front and a stock rear suspension with air bags.
Car: 87 IROC L98
That sounds exactly what happened to my old 383 back in 1999. Cast pistons and rod bolts spinning up to 7000 rpm. Hard to say exactly what the original cause was but it looked like one rod was thrown and one piston disintegrated.
Look anything like this?
Car: 1986 Iroc
Those pictures look eerily familiar Stephen. I will try to post a couple of mine. But it definately looks similar.
Car: 87 IROC L98
At least my heads were salvagable. I know they have at least 5 visibly bent valves but no damage to the heads. Some day I'll get them all set up again for a SBC I may build just to sell.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You boyz watch too much Nascar LOL, keep them revs low-make motor live long time.
6K all day baby
6K all day baby
