What will i run w/ a 1.8-2.0 60'?
Car: 1994 Jeep Wrangler
The topic is the question. My current best is in the sig. The next time i go to the track I will have BFG drag radials(@ or below 18psi), spohn lca and relocation brackets, spohn panhard rod, no front sway bar and 6 cylinder front springs. I am just wondering in general how many tenths in the 1/4 each tenth in the 60' is worth.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
just to let you know, with the new gear setup.... i spun really bad and did a 2.28 60 foot and ran a 14.7 at 90mph
previous run..did a 1.92 60foot and ran a 14.17 at 91.1mph.
two days later in what i thought was abit better conditions, i did a 1.88 60 and ran a 13.99 at 92.6mph.
this was all done with a exhaust leak and a going bad torque arm bushing /mount
old gears i went from a 14.2 at 95ish mph with a 2.02 60 foot to a 14.02 at 96.1mph with a 1.94 60 foot. then i went 13.89 at 96.6 with a 1.89 60 foot.
so definately some room for improvement.
Car: 1987 Camaro
Engine: 400 sbc
Originally posted by crawlin 25th
13.80 with a low 1.8, 14.20 with a 2.0....
- Justin
also keep in mind that my best run was made in july on a hot day (air temp in the 90s). my next run will be in later september or october.
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I'm in the same boat as of last Wednesday.
Have BFG drag radials as well @ about 20psi.
Couldn't seem to get my 60' under 2.0.
I'm stuck at a 14.2@94 or so.
I don't really burnout, just spin the tires a bit.
I know I should be able to get 1.8-9 60's, not sure how.
How/what RPM do you launch yours Orr89RocZ ?
Car: 89 Iroc-z
Transmission: TH400
i do a small burnout on my street tires, just enough to get some smoke coming out.
i stage and brake stall to about 2400-2500rpm. i got 2800 stall. then just let the brake out and kinda walk into the throttle. the brake stall gets it off the line and i go into the throttle, NOT mash, just depress kinda slowly to maintain traction. tires usually just hook and i goes thru the gears.
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
