wheels how wide
Car: 82 Camaro Z28
Engine: 5.7 350
Transmission: Turbo 350
wheels how wide
I have a 82 camaro z28 and i was wondering how wide of rims i can run in the back without rubbing tire i was thinking 15x7 in the front and 15x10 in the back and i have no i idea what size tires i should run either any info will help thanks!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
a 15x10 should work well with the right backspacing. i think you would want 5.5 inch of backspacing for 15x10s. 15x7 should be around 4.5inch. 15x8's use about 4.5inch.
i'm running a 26x11.50x16 m/t et street tire on my spare 16x8 irocz rims and they fit fine.
a 275 would fit on that 10inch wide rim. could try a 295 series tire..but might need some inner fenderwell work which shouldnt be too much work..just minor pounding if at all necessary. i think i heard of guys running 295's without any work at all
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
28x10.50 slick here with 15x8 with 4.5 bs on the weld pro stars...fit just fine. a little pounding on the inner wheelwell was needed though.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
15x10 Weld Rodlite with 5.5" backspacing with a 275/60/15 M/T ET Street Radials (white car in front)
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Originally Posted by kingdaddy305
Your kinda standin in front of the wheel lol
morrow
Jan 13, 2024 12:29 PM
Numbah-1
Sep 12, 2015 08:57 PM
punkmaster98
Sep 8, 2015 09:45 PM
