Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Going to the track if it does not rain.
Old Jul 10, 2006 | 11:11 AM
brutalform's Avatar
Going this Friday. I havent been there in like two months. Last time out the car went 11.60 @ 118, with a 1.54 60'. Well I bit the bullet, and took out the P/S pump, and switched to a manual box. Tommorrow its front end align time, and Pa. inspection. Am I out of line expecting to shave a tenth off? We'll see.
Old Jul 10, 2006 | 12:29 PM
87_TA's Avatar
Yes! the PA. inspection will do nothing for you! J/K.
You will see a gain from it, did you go s10 box or flaming river?
I would say a 10th is high, but very possible..
Let us know how it goes, what track? Pittsburgh raceway!
Old Jul 10, 2006 | 01:04 PM
brutalform's Avatar
I went with the S-10 box. If I get to go, I will be at Numidia. LOL, yes that sticker on the windshield is unneeded weight.
Old Jul 10, 2006 | 06:00 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
It always rains in NE Pa. Especially on friday and sunday. Forget about it.
Old Jul 10, 2006 | 06:21 PM
brutalform's Avatar
Are you going if you can?
Old Jul 10, 2006 | 06:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
it always tends to rain on raceday
Old Jul 10, 2006 | 08:28 PM
brutalform's Avatar
Unless of course, your car is sitting in the garage, needing an alignment, and an inspection, then its beautiful, with good air.
Old Jul 10, 2006 | 08:54 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
by taking off the ps pump belt, i droped .1 and gained 1mph...these were on back to back runs. then, i swapped the manual box in and took out the pump and whatnot, dropped about 25lbs from that...so all in all, that's approximately .125 that i dropped off the et.
Old Jul 10, 2006 | 09:19 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Ohh noo dont say the R word,bad joo joo there.What kind of weather did you run the 11.60 in? When you get your new intake and all on youll wanna just use that Superram for a shop stool lol, hello low 11s!
Good luck though
Old Jul 11, 2006 | 06:27 AM
brutalform's Avatar
Good luck though
Actually it was real good air.
Elevation: 970 ft
Bar: 29.30
Temp: 54.7
Hum: 60
The S/R will most likely get sold, either complete, with the 58mm T/B, or seperated, to recover the cost of the new manifold, and cam change.
I have two problems, working together, the S/R, and a 114* LSA cam.
That TPIS cam is working real good for you, I see?
Old Jul 14, 2006 | 01:27 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Axle/Gears: 3.73s
Elevation: 970 ft
Bar: 29.30
Temp: 54.7
Hum: 60
Goodluck tonite.And yep the cam works well.Especially for not intended to be a carb cam.Wonder if would work better at 108 or 106 lsa instead of 112.Good thing is my stock brakes and all work perfect,no vacuum issues.
Old Jul 14, 2006 | 01:34 PM
brutalform's Avatar
Hey thanks! I just got finished putting the skinnies on the car, and loading it up with my jack, and slicks etc. Probably will head out in about an hour.
I emailed TPIS, to see about that cam you are running. I asked if it is available with a .900 base cut, as my engine is "tight' inside. If they are too crazy with the price, maybe Comp can custom grind me one. Just got the intake today. Its still down the parts store, and I'll pick it up next week, as I owe $100.00 on it yet.
I will try to get some vids up tommorrow, if I have no problems.
Old Jul 14, 2006 | 05:26 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Good luck and keep the shiny side up.
Old Jul 15, 2006 | 09:25 AM
brutalform's Avatar
No new best.
No new best, but still had fun. Before arriving at track, a bank clock read 94 degrees. No weather info on the time slips. Ran the car 8 runs. My 60' were off almost 2 tenths, as the track was greasy, with my best of 1.678. Everyone I spoke to were off approx. 2-3 tenths, and 2-3 MPH, due to the heat. My manual steering conversion probably helped, but last night was not a good night to tell. My best run was 11.78@115. Floorguy was watching every run, and said I was spinning in second gear. He suggested we pull the pan, and change the spring in the 1-2 accumulator, to soften it up a bit. I'll try that before next time out. I have a video of an 11.88@115 run. Please excuse the angle, as my wife was learning to use my daughters new digital camera. Not making any excuses, as it was better than a GOOD day at work.
Video - 11.88@115 run
Old Jul 15, 2006 | 11:02 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Any time you drive it home from the track it's a good day.
Old Jul 15, 2006 | 11:42 AM
brutalform's Avatar
"I see" said the blind man, to his deaf son.
Lbibb
May 5, 2016 12:00 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
