Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
new best
Old Aug 19, 2006 | 08:49 AM
chikn305's Avatar
new best
Went to the local 1/8 mile track last night first 2 runs sucked wasn't paying attention and hit the rev limiter in second and ran 8.35 and 8.15. Everythihng went perfect on the next run and went 7.43 with a 1.87 6oft the next run lauched alittle better 1.72 60 and ran 7.35. The mph was off it said I ran 104 and 101 so I'm not sure what the mphs are.
Old Aug 20, 2006 | 06:36 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Was this with the car in your signiture or your black car with the nitroused 305?
Old Aug 20, 2006 | 03:06 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i believe it's the same car, just with a TTA motor instead of the little 305...good job! 7.3x's is good for like11.2x's and .3x's.
Old Aug 21, 2006 | 07:07 AM
chikn305's Avatar
Like mw said its the same car i put the TTA motor in it over the winter. I've been very impressed with this thing.
Old Aug 21, 2006 | 08:06 PM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Awesome times for your combo. How much boost were you running ?
Yeh, mph is a bit off, should be 95-96 ish
Old Aug 22, 2006 | 07:09 AM
chikn305's Avatar
I'm running 25lbs. Ineed to get some 65lb injects the 009's are pretty much maxed out.
Old Aug 28, 2006 | 06:35 PM
chikn305's Avatar
Went back to a different track ran 7.41 @ 97.61 1.7860ft. On the last run the front seal blew out of the tranny. So its time for the th350 with t-brake.
