estimate me a time?
estimate me a time?
pretty simple,
82 T/A
Engine
434" bbc
10.0-1
cam:
567/590"
248/258* .050
2800 stall
850 demon DP
approx. 475 hp
susp:
adj. torque arm
spohn LCA
moroso front trick springs
12 bolt, 3.90 gears
28" MT et streets
Car has been stripped of a/c and heat components, wiper motor, has fiberglass hood, and other misc. wieght stripped.
just wandering how hard its going to be to push into the 11s?
82 T/A
Engine
434" bbc
10.0-1
cam:
567/590"
248/258* .050
2800 stall
850 demon DP
approx. 475 hp
susp:
adj. torque arm
spohn LCA
12 bolt, 3.90 gears
28" MT et streets
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I'm guessing the weight of you and the car to be about 3300lbs.
With 475 flywheel hp and good traction my virtual engine calculator figures about 11.68 @ 115mph or 7.49 @ 92 in the 1/8th.
