Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
curious ab what power i should be making/what size tire and wheels should i get?
Old Jan 27, 2007 | 11:52 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
i have an engine being built for me....385 with HSR, bbk TB, afr 195 heads, comp cam 8-503-8, edelbrock TES headers and dynomax cat back. rear end is 277 with worn out posi.......i am looking at purchasing a set of 342 and limited slip o yes 1.6 comp cam RR i am curioius what power do you guys think i will be at? the stroker kit is eagle...
also after i do the rear end, i am looking at getting a set of wheels and some MT drag radials what size wheel and tire should i go for?
Old Jan 30, 2007 | 12:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i would think you'd be around 340-350whp well tuned maybe even more
what kind of tuning has been done to your car right now?
Old Jan 31, 2007 | 03:51 PM
camaroal9668's Avatar
Car: Camaro RS
Engine: 415 c.i.
Transmission: Glide
Axle/Gears: 4.56
I have an eagle rotating assembly in my 383,went over 400 passes in the 10's with no problems ,good choice...what size rim??
Old Feb 5, 2007 | 06:53 PM
Car: 92 Camaro
Axle/Gears: S60 373
i want to get a pair of wheels for drag radials for the car when i race it.....tryin to get input for ideal wheels size
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
