Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
New motor this summer, time estimates??
Old Apr 8, 2007 | 07:05 PM
fossilrunner's Avatar
Its not a camaro but it is a chevy and you guys are all pretty smart so I figured I would ask here. just pulled the tired 305 out of the nova this past weekend and the new 355 is goin in. car ran a best of 15.5 with the 305, 2.73 gears,and stock suspension. car weighed 3500 with me in it. we shaved weight off and new parts are goin. how do you guys think she'll do?
Motor
355ci sbc:
-3.48" stroke, 5.7" rods, 4.030" bore
-"186" double hump heads
1.94/1.50 62cc 160cc intake port
Flow: Intake- 239@.500
Exhaust-147@.500
-10.5:1 static compression,
-Crane 1.5 roller rockers
-holley 750 double pumper with proform main body,
-Edel victor jr intake with 1" spacer
-1 5/8" headers, 3" collectors
-Cam: Lunati 401b1lun solid flat tappet
-Adv dur = 280/288
-Gross lift - .525/.540 (.560/.576 with 1.6 rockers)
-Dur @ .050" lift = 247/255
-Lobe sep = 106*
-ICL = 100*
-Valve timing @ .006" lift:
Open Close
Intake: 23.5 43.5
Exhaust: 59.5 15.5
-proform electric water pump
-electric fan
-manual steering
-NOS cheater system(using 200 shot)
Front Suspension
-Moroso springs
-15x4 prostars w/ 165r15's
-sway bar removed
Rear suspension
-Mono leafs
-Comp engineering traction bars
-Rancho 9000 shocks
-15x8 prostars w/ 275/60 m/t radials@15 psi
-Subrame connectors
Drivetrain
-4.10 gears
-red neck performance 9.5" 3500 stall
-th-350
Car Weight
3250 w/ driver
Old Apr 8, 2007 | 07:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: New motor this summer, time estimates??
11s with spray, test it out and report back.
Old Apr 8, 2007 | 10:23 PM
knj8's Avatar
Car: 89 Formula Firebird
Engine: 357
Transmission: turbo 350, EDGE 3500 stall
Axle/Gears: GMPP Dana 44, 3.73 gears
my motor is built close to the same with a little smaller cam and 3.73's and runs 11.60's on a safe tune 100 shot. so you should see deep 11's easy
Old Apr 8, 2007 | 10:44 PM
I gotta call red neck tommorow and see if a 4000 would be better. also might throw a 250 shot at it. would like to hit 10's.
Old Apr 8, 2007 | 10:55 PM
knj8's Avatar
Engine: 357
a couple friends of mine runs ******* converters and have had pretty good luck with them. Edge actually tightened mine up without asking so the nitrous wouldn't blow past it. only problem with that is I didnt plan to spray it every run I would have liked mine to be a bit looser around 4-4500
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
bellez77
Sep 5, 2015 08:39 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
