Bypass or Not to bypass...Regulator question!
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Ok so im making my list so i can order the parts for my Fuel system so far this is what i have come up with.
-10 AN braided lines from tank to inline filter and an Aeromotive A1000
From the A1000 it goes to 1/2" hard lines up to the front. Then theres another -8AN inline filter, Then -8AN braided lines to the regulator, here's where my question is.
Im running a 950 HP Holley, im not sure if i should run a return system or not. I will still drive the car on the street, but not a whole lot as it has a pretty big cam and stall and will be on QTP's ALL the time. I have a regulator im looking at :
http://store.summitracing.com/partd...15&autoview=sku
Or if i dont go to bypass style, i will most likely go with this one.
IF i run return style it will be 1/2" back to the tank. Just looking to get opinions on what you guys are doing for fuel systems Thanks
Brandon
Brandon
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Bypass or Not to bypass...Regulator question!
neither link works, how about part numbers instead? Also, you should always go return style if you can, easier on the pump and cooler fuel as well.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A deadhead regulator works for many situations but is hard on the pump. I use a bypass regulator myself. It allows the pump to work at maximum speed and provides as much fuel as possible to the regulator. What the carb(s) don't need gets returned to the fuel tank. This provides a constant flow of cool fuel.
My fuel cell is up front beside the fuel pump and filter. #10 from the tank to the pump. #8 (1/2") to the regulator. #6 (3/8") return to the tank.
