Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Alignment Specs
Old Aug 28, 2007 | 08:26 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Alignment Specs
I'm fortunate enough to work at a shop with an alignment rack( infact i do the alignments lol)
i was reading the tech FAQs on the main page and saw alignment specs but due to page formating i cant make heads or tails of it lol..
i was wondering wat would be a good starting line for a "Aggressive Street" tune.
I drive my car every day but get hooked up on tire so wear isnt much of an issue.. and i do drive my car kinda hard.
this is all assuming i can align my car lol i think it may be too low.
BTW any specs in degrees would be great because thats what we use on our machine...
Old Aug 28, 2007 | 08:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Alignment Specs
Toe: Same as stock specs
Camber: Same as stock specs
Caster: 4-5*
If you play around with toe and camber, you'll get tire wear. The best you might hope for is to set the camber the same on both sides. Normally it's set to compensate for any road crown.
Old Sep 2, 2007 | 09:39 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: Alignment Specs
Caster: 4-5*
ah thanks... yea i need to fix my cambers... they are really negative right now. I have my car way too low.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
