Vortec motor, what do you think I will run?
I have a 82 camaro Z28. I put in a 010 350 4 bolt engine with lightly ported vortec heads that have been modded to accept .550 lift. I also have a voodoo 268 cam (227/233 @ .050 with .489/.504), performer RPM air-gap with a speed demon 750 (vac sec.) on top. Full MSD ing. (dist, box, wires, coil). I have a TH350 that has been built to withstand 550hp by PA racing so it has a shift kit and a small stall (1800-2000). Stock rear with 3.23 in it and stock suspension.
So after all of that any clues?
Thanks,
Andy
Thanks,
Andy
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Vortec motor, what do you think I will run?
12.9 at 102
cam/stall/gears not optimized for 1/4 mile at all
try a XE274 cam/3500 stall/3.73 and get 12.3s then
Im fine with 12.9s for now. I know i need a better gear and a better stall but the stall is going have to stay for now and im not going to put any money in the rear because im saving up for a 12bolt or 9". This is the first motor to play with. More motors to come
thaks for the input though.
thaks for the input though. Thread
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
