Get me 12's
Car: ws6
Engine: ls1
Transmission: m6
Get me 12's
Right now I am running 13.3 at 100. Im bored of being in the 13's, so I was looking for help to get me a 12.9.
I got an 89 iroc L98 with headers, catback, edelbrock intake and runners ported out, air foil, ported plenum, chip, 160 thermo, tb bypass, k&ns, gutten air boxes, afpr, marren injectors, msn ignition, and DR's.
Car: 78 Z28
Transmission: 3500/th350
Axle/Gears: 5.13
Re: Get me 12's
remove weight....about 300lbs
add power....about 40-55 hp
work on gearing, torque converter, suspension, ect.
add N20.
or any combo of the above.
witch way do you want to go?
add N20.
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: Get me 12's
Whats the 60' like now? You can't possibly take full advantage of drag-radials with a stock coverter and gears. Spray would be easier, heads and or cam would be more satisfying, really does depend on what you want out of the car.
Car: 1986 Camaro SC
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Get me 12's
what are your 60' times? get them to 1.7xx.. probably need a converter and about a 3.73 gear.. also, like other have said, a cam and tune will get you where you want to be..
Car: 1986 Camaro SC
Re: Get me 12's
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Get me 12's
Tpi car make a ram air set up. maby find some Ideas here I did it on a friends TPI car gave him a tenth and half off of his 1/4 times.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Re: Get me 12's
3.73 gears + a stall converter in the 2800 rpm range. if you have shorty headers, switch over to long tubes
make sure the coolant temp is between 140 and 150 when you run, ice down the intake real good, keep the front tires pumped up to around 50psi and the rears at 20psi or so. when you launch, dont stall the converter to its maximum speed... keep the revs around 1200 and on the last amber, flash it
Car: 1986 Camaro SC
Re: Get me 12's
On a completely stock motor yes. He has some breathing mods, I'll bet it pulls ok up to around 5000rpm. (TPI guru's feel free to interject.) 3.73's would put him across the line at like 5000rpm @ 100mph. Changing to the HSR or other TPI like alternative would further capitalize on the gains.
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Re: Get me 12's
depends... with a 100mph trap speed, 26" slicks, and 3.73 gears, hed be at roughly 4800rpms going thru the traps. considering you want to be just over peak power when you cross the finish line, 3.73 gears accomplish that exactly
FWIW the "old standard for TPI" 3.42s would put him at 4400rpms thru the traps with the same setup. if you want to wring every last bit of your E/T potential from a near stock TPI at the strip, 3.73s are the way to go
