compression
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
compression
Well since my trans blew up on me and messed the back of the block up i decided to go ahead and rebuild the motor. The last motor i had in it was ment for the street but never drove it so i just turned it in to a track car. But now i want to go all out and build a race motor for it i pick up a new 350 4 bolt block im probbly going to reuse my eagle crank and get some i beam rods. Im still using my dart 215cc platinum heads 64cc im sort of confused on geting the compression im going to need. Im hearing alot of bad things about geting compression with domed pistons. I know im going to need a preatty big cam to really use these heads to there potential. So i guess my question is what would be the safest way to get the compression im going to need. this is with race gas
Re: compression
WhteRbt
Sep 21, 2015 09:48 AM
