Nice launch picture
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Nice launch picture
his hood was a stock steel hood that a cowl was grafted onto. IIRC.
Front-
moroso BBC trick springs
lakewood 90/10 struts
remaining all factory
Rear-
stock springs
lakewood 50/50 shocks
tubular LCA's
stock panhard
wolfe craft anti roll bar-a must IMO after having it and looking back at before
Jegster adjustable tq arm- puts alot of anti squat in the chasis so i dont know if i'd be too worried about down track traction since it drives the tires into the pavement pretty good.
Rear-
stock springs
tubular LCA's
stock panhard
You know, that's actually surprising... I've owned a bunch of these cars and ran them all down the track, ranging from much slower than your car to a 4th gen that was MUCH heavier and ran about the same times, and I've never actually had one stay straight on a 1-2 shift at the track with a stock panhard rod. Every single one would jump sideways on the 1-2 shift, and it would go away if you did anything to stiffen the panhard rod.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Factory GTA hood, 4" fiberglass cowl, body guy molded it in for me. Said to do a paying customer it'da been around $700 to have it done, but the guy blended it flawlessly, even 6 yrs later you cant tell it's not a factory type hood, no cracking, dimples, etc...but i just wish no i'da went fiberglass to save some weight on this tank.
