T-top rules
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
T-top rules
How fast is does a car have to be before it requires a roll bar if it has t-tops?
I am thinking I will be in the high to mid 12's so I should be ok right?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: T-top rules
T-top cars fall under the same rules as a hard top. 6 point roll bar required at 11.49. Roll bar is good to 10.0 unless floor or firewall is modified. Then a full cage is required. A full cage is required at 9.99 and quicker.
My car got a roll bar when I was knocking on the door of 11's. At the time 11.99 and quicker needed a roll bar. When my car got into the low 10's, I ripped out the roll bar and installed a full cage.
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: T-top rules
Check with your local track as well....my track states that t-top cars must adhere to convertible rules....this rule has been on their website for several years now so, it may have changed without them updating it.
Car: 87 IROC L98
Re: T-top rules
NHRA tried to make the rule for T-tops the same as convertibles a couple of years ago but it was changed back before the start of the season.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
