what do i need to dipp 14's
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
my car runs a 15.30 bones stock..i wanna run a 14.80 /14.90
is there anything i can do?
like: 3.42s/slp runners
3.73/HSR( i like the best)
headers/intake
any kind of combo to make get into the high 14s
89 LB9 formy 700r
i have about an 800/1000 budget
thanks for your help guys
headers/intake
89 LB9 formy 700r
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: what do i need to dipp 14's
if you put a new set of headers and a 3 inch cat back you will probably hit your goal of 14.8 If you went with the hsr you would probably need bigger heads. And with that combo, it would get you into the 14's and with a cam you you go into 13.6's or lower.
Car: 89 Formula
Engine: LB9 TPI
yea?...what kind of stall speed should i get with the peanut cam and 2.73s
Something around 2500-2600 & 2.3 - 2.5 STR. Shop around, you can find a good converter that fits your budget. It will knock .3+ off alone even with the crap gears. Plus, it will be a lot more fun to drive, shift exstension of a good converter does amazing things for your ET's.
