Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Pro Comps
Old Jul 12, 2008 | 02:18 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Pro Comps
I had a little incident last yr. where I smacked a valve due to a pair of bad valve locks so I had a chance to pick these heads up very cheap even though I have read some not so nice things...Anyway, due to tight budget and comparing the cost to fix my darts I went for it....Well, let me tell you I am actually glad I spent the couple of bucks that I did, because I went a 12.2 right off of the street with no cool down except tire pressure of course then I hot lapped it to a 12.1.....These times were not expected by any means and the fact that it needed more jet only tells me that they will in fact go 11's with some tuning!! So, note to self not everything is true on the net!!
Old Jul 13, 2008 | 02:06 AM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Pro Comps
I have a set of pro comps on my 406. I run 1/8 mile tracks. 1st time out tonight, it ran a 6.42@ 105 mph. I don't believe everything I read either. Oh, I also run a red neck converter. Consistant 1.32/1.33 60 fters. My pro comps needed very little port work. They are for a high port intake, I didn't especially care for that, BUT they seem to work pretty good. They may not produce the #s that AFR gets, but they don't cost what AFRs do either
Old Jul 13, 2008 | 09:20 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Pro Comps
theres a local guy running the pro comps on his 331 sbf turbo combo in the low 9's... Just make sure your valvetrain is good to go and those heads do everything they need to do. I dont get in all the hype with brand name stuff.
Old Jul 15, 2008 | 03:38 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Re: Pro Comps
Wow!! Awesome times!! Yea, I was actually surprised because all of the bad mouthing, but all in all I am pleased... Especially for those times in the heat and untuned...So stay tuned for more updates!! lol
Old Aug 23, 2008 | 03:24 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Re: Pro Comps
Well, I finally made it back to the track again and it went into the 11's with more jet as I thought it would...11.82@114.6 ....Anyway, I wasn't able to do that much tuning because it seemed that every other car was leaking or breaking so I had alot of time to bs with people in the lanes lol...So, I will report back within the next couple of weeks...
Old Aug 23, 2008 | 08:54 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Pro Comps
I went outside today and my car wasn't there! oh no I thought, someone stole it! but sure enough as I looked harder I saw it that it was over in the bushes hiding from 1QWIKZ Good job... You see improvements from tuning and I lose power from it.
I'll probably see ya at Atco this week.... I got the plate hooked up and the 100HP jets in. Hopefully you wont have to clean up afterwards
Old Sep 7, 2008 | 07:09 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: Pro Comps
I am happy to see someone else have good luck with these pro-comp or patriot heads. My car runs great with them and it sounds like yours does as well, maybe now some people will see that they are not garbage. Probably not.
Old Sep 7, 2008 | 09:20 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Re: Pro Comps
Yea, I am definitely a believer now that they were just getting a bad rap but for the couple bucks that I spent I am over joyed lol!
no green
Jan 9, 2016 09:22 PM
djmarch
Oct 2, 2015 10:41 PM
