Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Nicked pistons
Old Oct 9, 2008 | 05:44 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Nicked pistons
I figured you guys would know best...
I found a awesome deal on some 12.7:1 JE forged pistons, only problem is 2 of the pistons have some little nicks in them. Can they still be used? The guy told me they can be filed down and should be all set. Heres what they look like..
Old Oct 9, 2008 | 06:51 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: Nicked pistons
have the set checked for wrist pin bore true-ness as well as make sure the ring lands haven't been compromised...i would still go two fresh pistons though..
Old Oct 9, 2008 | 07:03 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Nicked pistons
nothing would suck more than putting some money into a car and having a piston come apart because you used a questionable part. better safe than sorry
Old Oct 9, 2008 | 07:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Nicked pistons
If it looked like damage that had happened from rough handling while the piston was out I'd say it's probably no problem, but that looks like there was debris in the combustion chamber.
Old Oct 9, 2008 | 07:46 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Nicked pistons
If the pistons check out as good you can sand them down and smooth them out and if there are only two pistons bad call JE give them the part # and order two pistons. And I hope thay are not custom pistons you will pay dearly and have a min order.
Old Oct 9, 2008 | 08:08 PM
mw66nova's Avatar
Engine: 7.0L
Re: Nicked pistons
yeah, they normally want like $100 or so a piece with a minimum buy of 4 or something like that...it's crazy...
Old Oct 9, 2008 | 10:21 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Nicked pistons
Something has been through the engine, could have been a rock or something. I had a vent tube come out of the rear of my holley a few years ago. It damaged a couple of pistons like that. I just cleaned them up and used them. They were still in the engine when the crank broke, and they survied that too. Check the ring lands very carefully.
Old Oct 10, 2008 | 09:53 AM
Engine: 406sbc
Transmission: TH400
Re: Nicked pistons
The guy is selling the set for $100, even if I hafta buy 2 new ones through summit theyre only 120/each. Thanks for the input guys, really appreciate this. JE's website says that they make 12.7:1 with a 9.00 deck block, my block has never been decked so can I expect the compression to be a little bit lower?
Old Oct 13, 2008 | 10:40 AM
Engine: 406sbc
Transmission: TH400
Re: Nicked pistons
The ringlands and skirts look MINT. My only thing is, on JE's website it says deck height 9" my block hasnt been zero decked and is still 9.025" can I still use these? I know the compression will be down into the mid 11's if I can.
Old Oct 13, 2008 | 11:22 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: Nicked pistons
You are fine to use them. Most shelf pistons for sbc that I am aware of are made for a 9'' deck.
Old Oct 13, 2008 | 06:54 PM
Engine: 406sbc
Transmission: TH400
Re: Nicked pistons
Thats what I thought. Thank you for the help.
Eric-86sc
Feb 25, 2016 09:02 PM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
