Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Roll bar suggestions
Old Oct 18, 2008 | 07:45 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
Well I busted out an 11.41 all motor on my street car and now I'm looking for suggestions, tips and names of the recommended roll cage kits. As I'd like to actually spray the car next season ( it's a motor built for spray). So far from my reserch the comp engineering kit seems to be ok. but some of you guys probably know more than who I've talked to.
Please, heeeeeeeellllllllp
Old Oct 18, 2008 | 07:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Roll bar suggestions
i have comp engineering 8pt roll bar going in as i type this. SHould be done monday night or tuesday at the latest. I'll have pics then for sure
Old Oct 18, 2008 | 07:58 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
I'm going with the comp engineering as well.
Old Oct 18, 2008 | 08:07 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
That'd be great! Also post up any issues or what not if you could please. I know al cars will be different but it should give me a general idea!
Old Oct 18, 2008 | 08:15 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
I went with an Auto Weld kit. I did have to add one bend to 2 of the bars but otherwise it fit in very nicely.
Old Oct 18, 2008 | 08:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 5,6,8 point roll bar is good to 10.0. If you dip into the 9's, you need a full cage plus a lot of other stuff.
Old Oct 18, 2008 | 08:54 PM
Engine: 406sbc
Transmission: TH400
Good thing my goal is only 10.5's... running 9's gets expensive!
Old Oct 18, 2008 | 09:12 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
True but I think mid tens is what this setup will produce with the zex perimeter kit I have. I figure it runs 11.41 on motor and it gets harder to make the car faster and more HP so I'm thinking with the 11.41 383 on a 250 shot I should see my mid to low 10 goal. and I HOPE that I will be satisfied. because in the end this IS a street car really. lol So I'm really looking at the 8point.
of course I could be over shooting like when I built the motor thinking the car would be a low 12 second car on motor...turns out it's a low 11 second car on motor...
Old Oct 18, 2008 | 09:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i went 11.47 on motor with my 383. Could go more once i get abit more gear and fully launch it with full traction. On the realllly rich 150 shot i went 10.92 at 125 but i had very little traction.. i could have or should have went 10.7's atleast with .1 off the 60 foot that i usually get. I was doing 1.65 that night and usually go 1.55 on motor alone. I didnt spray off the line, i just walked into it cuz i wasnt sure what the nitrous would do.
this 150 shot is now leaned out to 12.0 to 1 air fuel and should realllly pick up. I expect 10.50's and better once i can fully launch it.
250 shot should DEFINATELY put you down into the bottom 10's
Old Oct 18, 2008 | 09:42 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
I'd be a happy man to say I have a low 10 second street car lol.
Old Oct 19, 2008 | 07:24 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
S&W race cars has a perfect fitting kit-- not so universal like a few others and easy to go 10 point if you ever needed
Old Oct 19, 2008 | 10:56 AM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
I used a wolf 6pt for a 4th gen and put it in my 3rd gen, it fit very nicely. no modfications. it was chrome-moly, jig notched, low side bars for use with door panels.
Old Oct 25, 2008 | 08:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
https://www.thirdgen.org/forums/inte...r-started.html
thread with some pics of mine.. got it back wednesday and forgot to get the pics in this thread
Old Oct 27, 2008 | 07:55 PM
camaroal9668's Avatar
Car: Camaro RS
Engine: 415 c.i.
Transmission: Glide
Axle/Gears: 4.56
We have S&W cages in both of our cars, they fit great. An 8 point would be fine for 10.50's
Old Oct 29, 2008 | 07:06 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Years back i bought the Jegster 8 point kit and was pleasantly suprised by the fit. I had a few fishmouths i had to open up/change the angle of, but every car will be a bit different since i'm sure all of our bars wont be in the EXACT same position. From the time my buddy and i walked into the shop and turned on the light, until we had 3 coats of spray paint on it and were shutting the lights off was 5 hours. It helps we had all the tools to make this effortless than some guys might not have and requires more work, but overall it went together very well.
J-money
Jan 4, 2019 09:45 AM
R13_Braz
Sep 18, 2015 05:00 PM
Lanz06
Sep 14, 2015 07:16 PM
87camaro87
Sep 9, 2015 10:29 PM
Fronzizzle
Sep 8, 2015 12:10 PM
