Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Hood or A arms???
Old Oct 30, 2008 | 07:24 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Hood or A arms???
I am looking to shave a little weight off of the front of my car this winter and am thinking either tubular front A arms or a fiberglass hood.
I already converted the front suspension of my car to a coil over set up so a set of tubular coilover A arms would be nice. But I am also considering a fiberglass hood.
Which change will result in shaving the most off of my ET? The A arms are unsprung weight wich is always nice to reduce but the factory hood is big and heavy.
Old Oct 30, 2008 | 08:03 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: Hood or A arms???
Weight wise I would say hood, if you went with a hood like glasstech they are really light. When the money is there get both.
Old Oct 30, 2008 | 08:56 PM
onebadzz's Avatar
Car: 1991 Camaro RS
Engine: 555ci BBC
Well take your hood off and put a air cleaner on the motor and run that car at the track and see if that changes anything. Thats free. Just an idea
Old Oct 30, 2008 | 09:08 PM
Car: 1987 firebird
Transmission: 4l60e
It is a fuel injected 383 LT1, it does not have a carb.
Old Oct 30, 2008 | 09:14 PM
onebadzz's Avatar
Car: 1991 Camaro RS
Engine: 555ci BBC
Sorry my bad, how about a tubular K member. I think that will take off a ton of weight also. Than you don't need to get the anything painted.
Old Oct 30, 2008 | 09:20 PM
Stephen's Avatar
Car: 87 GTA
Between a hood & a-arms, I'd say hood.
You get visual improvement as well as a weight loss. And your reducing the weight up high, compared to reducing weight down low, for a lower center of gravity from the weight loss.
Old Oct 30, 2008 | 09:32 PM
Car: 1987 firebird
Transmission: 4l60e
If I go with a glass hood it will be a stock style, I am not sure that I like the cowl and I realy do not like the ram air.
So I am looking at a little unsprung weight loss with the a arms, or 40lbs or so with the glass hood.
Old Oct 30, 2008 | 09:39 PM
Stephen's Avatar
Car: 87 GTA
I'm a big fan of the Jongbloed hood. It isn't a copy of any other design & simply enhances the lines that are already there.
Old Oct 31, 2008 | 06:56 AM
ezstriper's Avatar
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
hood would give you more...but don't try to run without....any weight gain would be offset but bad aero..
Old Oct 31, 2008 | 06:17 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
How about Drag Lites?
Don't bother with Tubular Arm/K Member for weight, only do those if you need header/oilpan clearance, you might lose 25lbs at most. (not to mention there expensive, alot of work to install, and pretty good chance there not gonna fit right.)
between the 2, I vote for hood.
Old Oct 31, 2008 | 06:36 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
The hood is the way to go because it's the biggest body part. I wouldn't drive that tubular suspension stuff on the street. That's why the General sent all that time in Mesa AZ test driving them.
Old Nov 1, 2008 | 07:59 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
I have no issues with driving my car on the street with all the tube stuff, and coil overs on it. Granted its not a daily but I still drive it around and cruises.
Hotrodboba400
Dec 10, 2019 07:07 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
