what size tires were they?
Quote:
oh, of course, but i did that years ago so i didn't have to do that today.Originally Posted by stage20
hammer mod? Quote:
mine are just little bitty 275/60/15's...Originally Posted by heff17
what size tires were they? Supreme Member
Quote:
Originally Posted by mw66nova
yup, fitment and mockup pics here, they clear the brake caliper no problem: Looks great, I just got them in 15 X 12 with the same 6.5 back space and the stock 92 PBRs will not fit in them.
The good part is the 315s clear on my car with the car 1.5 inches lower then stock.
Jerry
Quote:
9" with 5.5 would look the same twoards the outside of the vehicle while not having to cut up so much on the inside of the vehicleOriginally Posted by MaNiAk86
looks great matt! could the same look be achieved with an 8" wheel w/ 5.5in bs? cause u dont really "need" a 10" wheel for a 275 8" would be 4.5
oh looks awesome btw
i run a 5" on a 8. tucks a lil bit better, but its not a common backspacing on an off the shelf wheel.
centerlines bout the only one.
man, you make picking wheels waaaaaaaay harder than it should be
. what size tire is on the front?
. what size tire is on the front?haha, they're a 165/80/15 vw tire(they may be 85's...can't remember)...just search ebay for a 165r15 tire and you'll find some pretty awesome deals. i got mine for less than $100 shipped to the door. i went with these instead of a mickey thompson sportsman or the like because they're a radial and i'm planning to do more street driving. the mickey thompson/hoosier radial front runners are EXPENSIVE, and no taller than these ones anyways, so i said screw it, and bought the 165r15's.
165's are what you dont want with a lot of street driving. i know everyone runs them, but they arent my choice.
165s aren't rated for how much the nose of our cars weigh. Remember these were tires for a VW bug not a 3300+ pound car.
i was planning on springing for the sportsmans...i saw a guy blow one of those vw tires at 115 mph and tore up a really nice s10
ya I run the 28" tall sportsmans, I'm happy driving around both on the street locally for cruise nights and at the track.
arg....i'm gonna run 'em for now. the front of my car doesn't weigh as much as the front of alot of other people thirdgens...all al motor, no creature features, no bumper support, batter, nothing...just motor...and a 'glass hood. i've seen tons of people go down the track with these with good results...
the people i've seen have problems with these don't take good preventative maintenance measure to insure that they're not gonna have a problem on the big end. dry rotted tires, low pressure, etc.
we'll see what happends come tax season...
i've ran...run those same 165s just fine, short bursts of speed don't cause nearly as much stress on a tire as continous, long as you're doing the speed limit or passes down the 1/4 you'll be fine. Spend the money elsewhere
Quote:
you got too much roll out Originally Posted by xpndbl3
no more redlights with the taller tires.
i would imagine a 165 radial tire would handle as much weight as a bias ply front runner...... probably wont handle potholes all that well, though.
Quote:
main thing about the expensive front runner tires is they weigh half as much as those vw radials and also have alot less drag.Originally Posted by mw66nova
the mickey thompson/hoosier radial front runners are EXPENSIVE, and no taller than these ones anyways, so i said screw it, and bought the 165r15's. i highly doubt the mt or hoosier radial front runners are much lighter than these. i can see the bias-ply drag tires being lighter, but the radial street tires? eh...
do you know which ones i'm referring to?
very sweet mw. how much room do you have with them on the car? if you hit a bump will the rear hit the inside of the rim? how about turns with the front wheels? how close do they get?
Quote:
No, Please tell.Originally Posted by mw66nova
do you know which ones i'm referring to? Jerry
i highly doubt the mt or hoosier radial front runners are much lighter than these. The Hoosier and M/T are
21 lbs.
The Nexen, Kumho, Nankang and Federal are
16.4 to 17.0 lbs.
The Nexen, Kumho, Nankang and Federal are load rated at
1199 to 1201 lbs. at 118 mph.
The M/T is load rated at
992 lbs. at 130 mph.
The Hoosier is load rated at
965 lbs.
at 130 mph.So do you over speed the tire for a few seconds if you go over 118 mph with the 165s or over load it all the time with a 3200+ lbs car.
Jerry
Quote:
Please tell me what radial tire is load rated for a 3300+ pound car with a 4 inch wide rim.Originally Posted by xpndbl3
165s aren't rated for how much the nose of our cars weigh. Remember these were tires for a VW bug not a 3300+ pound car. Jerry
I believe all of the 195/70 tires would be...? But he's talking a drag style rim, which would be the 8 ply M/T for vehicles over 3k pounds.
biggesst thing i'm afraid of is if the car gets to where it should be, i'll be running mid 9's at around 140 mph. those vw tires would make me a little nervous, if i was sticking around the 12s and the 11s, i'd probably go that way, but the others just make me feel better lol.
ive had vw tires mounted on telstars (which are very close in weight to a prostar).Originally Posted by mw66nova
i highly doubt the mt or hoosier radial front runners are much lighter than these. i can see the bias-ply drag tires being lighter, but the radial street tires? eh...do you know which ones i'm referring to?
right now, ive got a set of prostars with hoosier front runners on there. they are WAY lighter.
Quote:
21 lbs.
16.4 to 17.0 lbs.
965 lbs.
at 130 mph.
Jerry
Jerry
i think my hoosers mounted on a prostar rim weigh around 21lbs. lol.......Originally Posted by JERRYWHO
The Hoosier and M/T are 21 lbs.
16.4 to 17.0 lbs.
965 lbs.
Jerry
Jerry
those weights i would imagine would be PER TIRE. so if you have a pair of tires rated for 900lbs on the front of the car,(1800# total) then youd most likely be alright running them on a 3000# car if you figure a 55/45 weight distribution. i know i have been so far, and so has hundreds of other guys.
Quote:
Jerry
Mickey Thompson Sportsman S/R Radial: 26x6.0-20lbs each $165/eachOriginally Posted by JERRYWHO
No, Please tell.Jerry
Hoosier Pro Street Radial: 26x7.5-21lbs each $162/each
neither tire is available in anything taller than a 26" tall tire, (i'd really like a 28") and i'm going back to a radial rear tire, and i don't like the sloppiness of the bias plys up front.
i run a 205/75/15 tire on the front of my car for 5 years. no issues on a 4" rim. drove it hard for having skinnies.
most brand of tires are 27.1" on a 5.5-6" rim.
mine were very close to a 28" measurement on a 4" rim.
fills up the well and looks killer, IMO.
thanks man! i'll look into those when it comes time to replace these....
stage 20, what wheels are those?
centerline telstars.
I run 195/65 15s on my dd. Have had them on since may and drive about 450 miles a week. Sharp turns and lots of bumps (normal Louisiana) and they look fine. No unusural wear, have never weighed this car but i would geauss its probly heavy. Never done anything to take weight off.
1320 are you still running stock front brakes? if so how did you get those center caps on the front wheels?
Quote:
CTC, or you just drive over for a nice pic?Originally Posted by 1320_Guy
good times!
screw roll-out, yank the tires and ride!
If it picks 'em up decent tire roll-out doesn't really matter.
If it picks 'em up decent tire roll-out doesn't really matter.Supreme Member
Still running stock brakes, I used a 1.5" spacer.
That picture was taken at Crusin the Coast.
