Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
rear bumper hold shape without bumer support?
Old Mar 17, 2009 | 09:51 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
looking to shed some pounds for the track, but i dont want to sacfrice my bumper sagging.
any guys had it out for a while with results? bumper all wavy or still holding shape?
Old Mar 17, 2009 | 10:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: rear bumper hold shape without bumer support?
Mine has kept it's position. It makes it difficult if you have to push the car around.
Old Mar 17, 2009 | 10:05 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
mine's holding fine, but it'll almost definitely chip the paint if you push it with a 4 wheeler or something
Old Mar 18, 2009 | 09:49 AM
Shagwell's Avatar
Car: projects.......
I built some fairly lightweight support behind mine utlizing 1/2 electrical conduit and some bed-frame angle iron and four short pieces of 1/2 pipe. Keeps the bumpers form, and is solid enough to push the car around by. - I attached the four pipes to the body(one on either side, two splitting the middle) and welded a short piece of angle iron to them at the bumper angle. I then connected between them with the conduit and ran a couple angled braces using the conduit. All together it weighs less then the plastic "egg-crate" energy absorbent did and I can still push the car around as needed.
Old Mar 18, 2009 | 08:31 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i used a hole saw and swiss cheesed mine
Old Mar 19, 2009 | 07:37 PM
PROSTOCK5031's Avatar
Car: 91 Bird
Engine: Pontiac 500 + CID
Transmission: 3 speed auto
Mine looks fine...Quay made the stock bumper mounts the mount for the Chute. had it out since 03
Attached Thumbnails rear bumper hold shape without bumer support?-pdr_0062.jpg
Old Mar 21, 2009 | 11:29 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Anyone remember what it weighed??
Old Mar 22, 2009 | 08:45 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
18.x
support
grid
bolts.
the front is 25+
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
