Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Results from first track visit
Old Jul 1, 2009 | 09:35 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Alright, I finally got out to the track tonight. Weather called for rain, but I risked it, glad I did.
I got 3 runs in with the tired ole 305.
Specs:
85 Camaro
LG4
KN Filter
AC Delete
Smog Delete
Hooker 2460 headers
Dynomax 2.5 inch cat-back
Shift Improver kit in 700r4
3.42 posi rear
No carpet, rear seats,rear plastics
running 245/50/16s all around, Falken Ziex Street tires
Alright now for the times.
The first run Ive ever made, botched it like mad.
Reaction time :.465
60 Foot :2.570
1/4 ET : 16.107
MPH :88.21
Second run was much better time.
Reaction time :.611
60 Foot :2.179
1/4 ET : 15.165
MPH : 88.97
Last run was alright, beat the 300 horse Altima in the right lane!!
Reaction time :.003
60 Foot :2.351
1/4 ET : 15.334
MPH : 89.51
The last run it was starting to sprinkle so I called it a day, Im reasonably happy with these numbers considering its a 305. I had no traction issues whatsoever after the first run (third run had a little bit but the track was getting damp) it was about 60 degrees with 78 percent humidity.
So were these good times? Where should I go from here? Im already getting ready to build a 350, but are there any cheap mods to be done to the LG4 to drop my time?
Old Jul 1, 2009 | 10:50 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Results from first track visit
A 150 shot of nitrous.
Old Jul 1, 2009 | 10:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
HP is consistent by comparing the MPH. Traction is an issue looking at those 60' times.
It's making roughly 190 uncorrected hp estimating a 3300 pound race weight.
Old Jul 2, 2009 | 07:05 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I'd be looking to get that 350 together. I was going to try to give some suggestions to make that car faster but i'm not sure what to even do. MAybe put in a cheap jegs cam ($50) and put in a 2400 stall converter and a pair of drag radials. You would get it into the low 14's i'm sure?
Old Jul 2, 2009 | 10:34 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, if he was goig to stick with the 305, i would give some suggestions, but he is going 5.7, so there really is no point in wasting money besides a nitrous kit.
Old Jul 2, 2009 | 10:50 AM
Camaro5690's Avatar
The only traction issues I could really feel was the 1-2 shift, it chirped em everytime, the last run was the most noticable, but as I said, it was a very damp day. That very well may have messed with it, I am gonna try to make another trip out when its drier, and see what I get. I was hoping maybe to drop it in to the high 14s before I do the engine swap. Maybe do an aftermarket air cleaner?
Also, is there anyway to make it shift into 4 at WOT, this was killing my time, I had to let off so it would shift then get back on it.
Old Jul 2, 2009 | 06:14 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Reaction time :.003
.... almost
Old Jul 2, 2009 | 07:05 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
the single 2.5" dynomax exhaust could be a choking point, and it will be a choking point when you put the bigger motor in so go ahead and upgrade that and you should see some pretty decent gains.
Old Jul 2, 2009 | 07:09 PM
Camaro5690's Avatar
Ill look into getting a quote from a local exhaust shop. Im gonna have to have the y-pipe modded too, the only reason I went 2.5 is cause I was running out of monay at the time and needed it on the road.
Also would a HEI Incap supercoil help me out at all? There a very good chance I would be reusing it on the 350 anyways.
Old Jul 3, 2009 | 08:39 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
2.5" will choke about 20hp out of your motor at least.
You can do a few additional things for cheap HP:
Electric fans if you have a clutch fan
Underdrive pulley
Tune carb using an A/F gauge
Old Jul 4, 2009 | 09:36 AM
Camaro5690's Avatar
What exactly to underdrive pulleys do? Are they good or bad for the street? Its something I am interested in seeing as I can reuse them on the 350 when I do the swap. Also I am gonna try to get a quote on an exhaust today sometime. Im also currently looking for another 700r4 to build myself, seeing as mine is messing up the 2-3 **** really badly, revs to the sky, I have to let off for it to shift.
Old Jul 4, 2009 | 11:58 AM
AlkyIROC's Avatar
Car: 87 IROC L98
You don't want to go into OD. You want a different gear in the diff so you cross the finish line at or just before you need to shift to OD. A taller tire will also help. The ones you have now are less than 26" tall.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
