Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
havent been on in a while T/A update
Old Aug 3, 2009 | 07:59 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
well a few things have happend since i ran my 13.07 last fall. this spring i got my drag radials on but my motor started makin some rocker noise and i had to tighten up the lash on 2 cylinders(not a good sign on hydraulic cam) i actually brought the car to a dyno just for to see what itd lay down. results 235hp and 280tq.... hmmm last year i trapped 107 so i knew that 235 was way low. i parked the car after that while i gathered parts for hydraulic roller cam swap. here is what i found when i pulled my old cam out of it
as you can see a couple lobes are about round
2 bad lifters
my new cam is a comp hyd roller w 235/249 @.050 .510" .522" on a 107lsa. i had to go from 1.6 rockers down to 1.5 so i picked up some aluminum full rollers from summit.
here is what it looked like as i waited for the correct timing set to arrive. it took 3 sets before i got the right one (damn 96-98 vortec blocks)
got it running a few days ago took it for a spin and it felt real lazy so i tried adding some timing and found that my new summit billet dist(only 500 miles on it) took a **** and the advance arms were floppin all over the place and adding no mechanical advance. summit is sending me a replacement as a one time courtesy exchange cause it is out of its 1 year warranty. props to summit for helpin me out i cant wait to get it in there and dialed in.
Old Aug 3, 2009 | 09:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: havent been on in a while T/A update
nice...keep us posted...
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
