Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What stall speed to go with?
Old Aug 4, 2009 | 12:07 PM
tcollinssr's Avatar
Car: 88 formula
Engine: 5.7
Hey guys! Trying to figure what stall speed to go with. the cam I have has a adv duration of 280 intake 290 exhaust @ .005 lift. duration @ .050 is 212 intake and exhaust. with 112 lobe separation. car still has stock 9 bolt rearend. 3.08 gears. had car dynoed and tuned 240 hp at rear wheels. bolt ons include hedman long tubes, 58 mm throttle body, 32 lb injectors, painless pefect engine management system. Thanks in advance!!
Old Aug 4, 2009 | 12:12 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: What stall speed to go with?
min 2500 but a 3000 would be better. with the 700r4 you can get a lockup converter so highway cruising will still be good
Old Aug 4, 2009 | 12:18 PM
tcollinssr's Avatar
Car: 88 formula
Engine: 5.7
Thanks maniak!! Thats what I was thinking but was not too sure.
Old Aug 4, 2009 | 03:23 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
A full size street converter with a 2600-2800 would work well. It would retain the factory lock up and can be bought under $300.
Old Aug 4, 2009 | 06:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The camshaft is going to want a stall speed around 3000 for street strip. For full race 3500-4000 would be better.
You diff gears are not matched for the camshaft or recommended stall speed and will hold back a lot of performance.
Old Aug 5, 2009 | 11:11 AM
Shagwell's Avatar
Car: projects.......
x2 - 212@ .050, I would think Stephen is shooting a little high, but then again (performance wise) more stall would help off-set the less than optimal gearing.
Old Aug 5, 2009 | 05:55 PM
tcollinssr's Avatar
Car: 88 formula
Engine: 5.7
Thanks guys for all the input and help. I know the diff gears are too high going to be replacing rear end over winter. Probably a strange unit with 3:73 gears. Thanks again!!
Hotrodboba400
Dec 10, 2019 07:07 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
