Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Slick to Drag Radial
Old Aug 6, 2009 | 11:33 AM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
i just took my 28x10.5 slicks off and put on a M/T 275/60 drag radial.
Any tips on tire pressure and also shock settings? Should i stiffen up the rear or soften it?
Old Aug 6, 2009 | 12:27 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Slick to Drag Radial
stiffen the rear up, get those tires planted and keep them that way. start at 19lbs of pressure in those radials that should be in the neighborhood pressure wise, what shocks are you running out back?
Old Aug 6, 2009 | 12:58 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
we run 18-19 psi in the tires. the like to be bit hard.
you might find out that double adjustables are gonna be you're friend
Old Aug 6, 2009 | 02:03 PM
Iroc Adio's Avatar
Car: 1987 IROC
i have QA1 Double Adjustable coilovers in the rear. Each **** can go up to 24 clicks for rebound and compression. how stiff should i go?
i also have LCA relocation brackets, set on the bottom hole
Old Aug 7, 2009 | 07:46 AM
chikn305's Avatar
You want to hit the tires hard and keep it there there are alot of great tips on yellowbullet.com in the stock suspension section
Old Aug 7, 2009 | 04:35 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
on my et streets they love 20 psi the best
Linson
Oct 24, 2025 02:00 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
