took the 305 to the track
Car: 1991 Camaro RS
Engine: 305 TBI
i wanted to break into 14s,so im little dissapointed.
but my times of the night were:
16.3 @91
16.3@90
15.8@90
15.6@90
15.5@90
15.3@90
16.3 @91
16.3@90
15.8@90
15.6@90
15.5@90
15.3@90
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: took the 305 to the track
Cannot be disappointed with poor numbers from a 305. Hell, i think i was trapping 85 MPH in a 305 i had so yours runs WAY better than mine did.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Consistent MPH so it's making the same HP. Need some better tires to make that ET more consistent.
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
what was your 1/8 time and MPH
Car: 1991 Camaro RS
Engine: 305 TBI
heres a slip i had laying here
60' 2.41
330 6.72
1/8 10.17
MPH 71.37
1000 13.13
1/4 15.63
MPH 90.76
but im trying to sell this car.
60' 2.41
330 6.72
1/8 10.17
MPH 71.37
1000 13.13
1/4 15.63
MPH 90.76
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Should be no reason for it to not have the power for a 1.9x 60' time that should make your 15.6 into a 14.xx.
Car: 1991 Camaro RS
Engine: 305 TBI
yea figure i could do that next things i was gonna do was some nice tires and locker rearend...but got in trouble with johnny law today and need to sell the maro.
Car: 1991 Camaro RS
Engine: 305 TBI
Hedman Longtubes
2.5in Xpipe
3.23 gear
timing bump
open element
no a/c or smog
eibach sportlines
kyb shocks
subframe connectors
car weighed 3330 with me in it.
2.5in Xpipe
3.23 gear
timing bump
open element
no a/c or smog
eibach sportlines
kyb shocks
subframe connectors
i run a 9.5 in the 1/8, and that was with 2.73 peg leg on stock exhaust manifolds
.19 RT
2.2 60'
6.5 330'
9.5 1/8
that was losing traction off the line and shifting early
you may want to play with your timing, or maybe a stronger ignition
i havent been back since the 3.23's and a bunch of my other mods
.19 RT
2.2 60'
6.5 330'
9.5 1/8
Car: 1991 Camaro RS
Engine: 305 TBI
i hit a 2.1 60 one time.
my timing is at *8,it seems to feel good for the low end power on the street.
i believe most comes down to my worn 225/60/16s
i dont know sometime slick worn will hook up better try droping your air pressure in the pretty low
just time seems slow even losing traction because i lost traction and was shifting early
i had some of my mods that are listed in the garage, but i would figure with your mods we and you having better gears than i did at the time of the run i made, i dont know man seems wierd
Street Lethal
Apr 30, 2019 12:14 PM
