Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Nitrous safety equiptment?
Old Nov 21, 2009 | 12:09 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Just wondering what else I would need for my new nitrous setup. I have a blow down tube but I know thats not everything. We have a IHRA and NHRA track somewhat close by so I'm curious what the rules are to run nitrous in a hatchback car.
Old Nov 21, 2009 | 12:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Nitrous safety equiptment?
If the bottle is in the driver's compartment which is anywhere inside a third gen, you need a blowdown tube. That's it. Other than that, it's whatever safety rules are required to use nitrous such as a thermostatically controlled bottle warmer etc.
Old Nov 21, 2009 | 12:53 PM
Engine: 406sbc
Transmission: TH400
wow I didnt think it could really be that easy. Thanks for the info.
Old Nov 21, 2009 | 02:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
What else would you think there should be. There's nothing specific about mounting the bottle in the car other than having a blowdown tube. All the other safety stuff required for NOS is the same in every car. The most important is that you should have a WOT switch so that the NOS can not be activated unless the throttle is at WOT. The switch can be mounted on the carb, throttle body or mounted on the throttle pedal linkage under the dash. As soon as you back out of WOT any amount, the NOS shuts off. It prevents you from blowing the engine by trying to use NOS at part throttle, idle etc.
Old Nov 21, 2009 | 06:53 PM
Engine: 406sbc
Transmission: TH400
Yeah it's setup with a WOT microswitch and I'm using a activation switch on the dash as well so I can run it WOT without it turning on.
Nervous2
Oct 8, 2015 10:53 PM
Buickstaged
Interior Parts Wanted
Oct 4, 2015 11:49 AM
PeteK825
Sep 22, 2015 10:47 AM
WhteRbt
Sep 21, 2015 09:48 AM
anesthes
Sep 18, 2015 12:34 PM
