Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
super victor help out any?
Old Jul 29, 2011 | 07:06 AM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I have a 388 stroker. 10:1 comp. Dart 215 platinum ironeagle 64cc chambers non ported. Soild roller .606/.606 lift 286/294 dur. adv. 850 cfm proform carb victor jr intake unported. Engine makes most torque around 4800rpm. Makers most hp around 6500rpm
. Shifting at 6600rpm. Dist locked down at 38*. Turbo 400. 4.11 gears
Currently running stock imported Vic jr. And unported platinum iron eagles
Based on the head flow data I found online for my heads and the Vic jr intake it looks like the super Vic flows alot more equal to my heads. See below.
Dart iron eagles 215cc
Lift. Intake flow. Exhaust flow
.200. 136. 109.
.300. 193. 158.
.400. 239. 198.
.500. 273. 208
.600. 289. 214.
.700. 293. 219.
UNported Super Victor
Roughly 298 averaged across all 8 runners
Unported. Victor Jr. (CURRENT INTAKE)
Roughly 240 averaged across all 8 runners.
Is there any to gain with this?
Old Jul 29, 2011 | 10:13 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Re: super victor help out any?
where does the converter flash too? doesn't the super vic make power to like 8000 rpm? may see a drop in mid range tq. not sure if you have enough cubes for it
Old Jul 29, 2011 | 10:48 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
don't you already have way too small a converter for the combo? I don't see this swap helping at all.
Old Jul 29, 2011 | 11:30 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
depending on your altitude, you might need a bigger carb too, for drag racing anyways...
My father races a 383 with pro topline heads alum. with lil bit bigger cam and but he shifts about where you do. We are at 600ft elv. and hot days it still reads a lil vac.
your heads are good, but I don't think that they will out flowing the intake or carb....
it won't hurt to try
but changeing the intake for a higher flowing one AND keeping the same sized carb usually doesn't do much of anything... You would have to buy a bigger carb or tune your butt off... to see any difference...
I always make drag carbaration like a "funnel"
Very big carb (down tuned to what is needed)
Big intake (port matched to...)
What ever the intake port can do......
I think you already have that....
short answer to your question.... Is there any to gain with this?
Highly dought it, without porting heads or bigger heads
Old Jul 29, 2011 | 12:27 PM
91_B4C_RS's Avatar
Thanks for the help guys drolly gonna just clean up the Vic jr a lil later on. Next on list is a different converter.
Old Jul 29, 2011 | 01:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Just port the victor JR out. Theres hp to be made there, that jr is a restriction. 10-20hp likely in just getting the plenum sorted out and good port match to the heads. Get that intake flowed and have someone even out the flow across the runners and hopefully gain 20-30 cfm.
Old Jul 29, 2011 | 02:07 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Torque is a nice thing to have in a motor. Im sure these guys will agree. Torque = useable power. When you take all the torque away from a motor your left with a motor that is either full throttle performance or no performance. So than you end up to be the guy with the 2 inch open headers, 4.56 gears, 5800 stall converter and your printing 11.50 slips.
Leave that Victor JR on there. I would almost be willing to be that if you swapped out a RPM AIR GAP and a 750 carb that your car would run the same number or better.
Old Aug 1, 2011 | 07:50 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
from my own experience with a vic jr. vs. a super vic. I ran the vic jr then went to the super vic and to my surprise I lost a lot of torque and throttle response. I went back to the vic jr and had it port matched to the heads. The ports on the super vic are much bigger than the jr. Also a interesting thing about the RPM air gap manifold is the port size on it are much bigger than the vic. jr
my combo is 355 10.5-1 , 6 inch rod, AFR Comp 195 heads, solid lift flat tappet cam, .548/.560 lift, 261/266@ .05 dur 106 LC on 102 CL, Vic jr manifold, 750 cfm holley built by the CARB shop, 1-3/4 hooker LT.
Old Aug 1, 2011 | 09:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you're making peak HP at 6500 and only shifting at 6600, you should probably go higher. 7000 rpm shift point would be better as when it shifts, the rpms don't fall too far below the peak HP. Once you get moving, you want to stay around the peak HP numbers. Peak torque just gets you off the line.
Based on those cam specs, you should have a converter that stalls around 4000 rpm.
Old Aug 7, 2011 | 07:10 AM
RaisinHale's Avatar
Car: 85 IROC-Z
Engine: 355 SBC
Axle/Gears: Moser 35 spline w/ 4.56 gears
I would port match the vic jr. I did this over the winter and it was worth a full tenth with my setup.
I'm running a 355, 11.5:1, Canfield 220cc heads, solid roller 630/630, Holley 750 HP.
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
