Mini tub 2.5" ID springs
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
For those of you that did a mini tub, put spring jacks on the upper spring pocket and used 2.5" ID coil over springs in the stock location: What brand, length, and rate spring are you using?
Thx
Thx
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Mini tub 2.5" ID springs
the wolfe spring kit I'm using. Whatever comes with it, although some guys run 12" springs in a lighter spring weight. Depends on how much the rear of your car weighs, no set number.
MrPackstin
Oct 25, 2017 08:09 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Dragonsys
Sep 25, 2015 03:51 PM
