Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What are your goals for the 2012 racing season?
Old Mar 1, 2012 | 08:44 PM
  #51
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: What are your goals for the 2012 racing season?
Gave my car a 30th b-day present today. The motor made more than I ever expected. You can see the vacuum pump sucking air on this pull. We had to fix a leak after the pull. I dynoed a 4500 carb and a 4150 for class racing. The 4150 made 15 less hp. That is one heck of a 4150 carb....
http://www.youtube.com/watch?v=6KiF8...ature=youtu.be
I tried to fly Gary in for tuning but he was unavailable today.
Old Mar 1, 2012 | 08:51 PM
  #52
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds great !!
Old Mar 1, 2012 | 09:47 PM
  #53
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
LMAO
Old Mar 2, 2012 | 08:38 AM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Might be buying a new rear end finally... just not sure what. 12 bolt or 9 ", moser or strange or others? decisions decisions.
Old Mar 2, 2012 | 12:17 PM
  #55
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I would like to be satisfied in 2012 with something......anything. I'm always thinking theres a better car out there for me. A better combination, a better body style, better street mannors, faster time slips, better sounding stereo..... Bigger *****, firmer butt, blonder hair. Oops vered off...
2012 = hope to be satisfied with my '87 T-type build which I think will run 11.50's with a grandmom tune and 10.80's on the track tune. so far been driving it everyday and it's a great, quiet street car.
Old Mar 2, 2012 | 01:28 PM
  #56
xpndbl3's Avatar
Car: 1984 Z28
9" for sure, I've been very happy with my moser, going on 6 years I've had it so far.
Old Mar 2, 2012 | 02:01 PM
  #57
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
I hope it's holding up with those 14.0's your after......
Old Mar 2, 2012 | 03:02 PM
  #58
xpndbl3's Avatar
Car: 1984 Z28
Just barely, but it does alright.
Old Mar 2, 2012 | 06:33 PM
  #59
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I just need to use 4th gen brakes thats all my main requirements are. I seen your moser install/setup thread and it looks like alot more work than I imagined. It thought they came ready to bolt in and install??
Old Mar 3, 2012 | 01:32 AM
  #60
xpndbl3's Avatar
Car: 1984 Z28
someone sells a full assembled 9", can't recall off the top of my head, but you need the axles off to press on the bearings behind the factory caliper brackets. If using strange brakes, etc then the bracket has an opening for the axles. Takes about 2 hours for me to put one together if I'm taking my time.
Old Mar 5, 2012 | 01:53 PM
  #61
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Get the car off the jackstands, and moving back under its own power. Make at least on TnT low 11's are the immediate goal.
Old Mar 5, 2012 | 04:01 PM
  #62
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
12's... If I can figure out why my 700R4 keeps shifting out of 2nd by itself that should be no problem.
Old Mar 5, 2012 | 04:16 PM
  #63
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
run in the 11s after 4k stall
Old Mar 5, 2012 | 05:30 PM
  #64
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Wouldn't mind mid 10s on just nuts...
Old Mar 5, 2012 | 07:25 PM
  #65
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Ill be happy if I can get into high 12s motor and high 11s on a 75/100 shot.
Old Apr 5, 2012 | 09:50 AM
  #66
86superstreet's Avatar
Car: 1986 Camaro
Engine: Chevy 555
Transmission: FTI Powerglide
Axle/Gears: Moser 9" w/4link , 4.56
To make it past 2nd round in IHRA top dragster a end up in top 3 in points. also win more than my brother this year, the year just started and he has 3 wins and i have 2 so im on his heels
Old Apr 5, 2012 | 10:19 AM
  #67
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
my goals have changed slightly...i just want to get back to the track with a working car now! msd has deemed my ignition box junk and is sending me a new one...eventually...they're on back order
Old Apr 6, 2012 | 07:12 AM
  #68
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Those 6010 boxes don't seem to be very reliable. I was disappointed last year when my box went up in smoke for no reason. I bought another box to use until MSD sent me a replacement box, it took them about 2 weeks I think. I kept the replacement box so if it happens again the car won't be down.
Old Apr 6, 2012 | 07:18 AM
  #69
mw66nova's Avatar
Engine: 7.0L
yes, i'm seeing a trend. i'm not going to spend any more money on it...just wait till i get my box back. having the car down means more study time...
i'm looking at the front distributor drives now...msd makes good product when you get into there 7 series boxes and stuff, so i was thinking of a distributor drive, and a 7530T box or something like that....would give me lots of room to grow. just don't know how to tackle things like timing marks and other odds and ends that you need to do when going to a distributor. wonder if someone will come out with a more reliable box than the 6010? or if msd will step up there program, and make like a 7 series version of the box with more capabilities? i'd love to keep my coils if i could...
Old Apr 9, 2012 | 04:15 PM
  #70
bclowrider's Avatar
Car: 82 camaro
Engine: 350 40 over 13 :1 pistons
Transmission: th 350 with 5000 stall
Axle/Gears: 9 inch 513 gears
hoping to hit 6.70 in the 1/8 with the new rearend and gears.
Old Apr 12, 2012 | 03:57 PM
  #71
tsfso59's Avatar
Car: 82 Z-28 (Cert 8.50)
Engine: 416 LS3 / 1050cfm
Transmission: Powerglide w/brake
Axle/Gears: 9" 4.86, 4-link
Matt couldn't you just use a MSD 6301 LS Trigger converter? Sounds simple enough if it actually works....looks good on paper.
Old Apr 12, 2012 | 05:52 PM
  #72
mw66nova's Avatar
Engine: 7.0L
instead of a crank trigger? maybe? i'm unfamiliar with that part number...i'll take a look at it. that could be the answer to this whole thing!
Old Apr 12, 2012 | 06:47 PM
  #73
tsfso59's Avatar
Its' designed to convert the factory LSx crank trigger signal to a 12 volt square wave signal that will trigger a conventional MSD 6 or 7-Series Ignition Control......
Old May 13, 2012 | 02:21 PM
  #74
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Updates on my goals:
So far my goals have be complete for the beginning of the season. Running low 14's, won a few rounds so far for Points in sportsman. And the main thing...the car is still running good and has been quite consistant for a boosted application!
14.02-14.26 in the last 10 full passes when I wasn't on the brakes or peddling. Car definitly passed my exspectations.
Old May 13, 2012 | 04:35 PM
  #75
adamemerson's Avatar
Car: 96 Z28 & 89 RS
Engine: Lt1 & 383 Stroker
Transmission: 4l60e & t5-5speed
Swaping the top end on my motor. Hope to get down in the low 8s or high 7s (my home track is an 8th mile)
Old Jan 4, 2013 | 11:37 AM
  #76
skinny z's Avatar
Waiting for the 2013 thread...
Old Jan 4, 2013 | 11:58 AM
  #77
mw66nova's Avatar
Engine: 7.0L
well, i met one of my two goals that i set: made the Dean's list at school this semester
barely went racing at all though as a result, and changed the whole car up and now rocking a t56 and a junkyard 5.3. the 6.0 is sitting on the stand waiting to go to the machine shop, and the th400 is in a turbo 4.8 car in kentucky running bottom 9's/upper 8's.
Old Jan 4, 2013 | 12:24 PM
  #78
skinny z's Avatar
....made the Dean's list at school this semester...
Congratulations. It's easier to race with a degree!
Old Jan 4, 2013 | 04:09 PM
  #79
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Originally Posted by DIGGLER
its not looking good. lol
didn't make the fall race but in the 4's pretty easily now....maybe this Feb.
Old Jan 4, 2013 | 04:31 PM
  #80
mars061's Avatar
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
Shave .13 off and run 10's.
Not as easy as it sounds cause I have to add the weight on a mild steel 6 pt. rollbar.
Old Jan 4, 2013 | 07:06 PM
  #81
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Yeah I know. I was a little slow this year
Old Jan 4, 2013 | 08:34 PM
  #82
fasteddi's Avatar
Car: 1991 Camaro RS
Old Jan 4, 2013 | 09:30 PM
  #83
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Originally Posted by UnstableAviator
I've really only driven my car about 150 miles since the LS1/T56 swap due to winter, but I'd like to get the stock LS engine and suspension as dialed in as I can and just see what I can run. I'd be thrilled with a 12.50 or better, which I think is absolutely feasible. My car isn't a strip only car, and I do think the lighter weight 18lb flywheels will impact my 60' times. Also a "bummer", I can't run my skinnies due to the LS1 brake upgrade. No big deal, just gonna have to save some money and buy some 17" front runners later on.
2013, I hope to have the engine significantly upgraded with AI heads and cam, and I'm thinking low 11's is a possibility then...that'd be sweet.
GOAL......MET. Ran 12.30 with bigtime bog, then changed to a 4.30 after breaking the 9" and ran a 7.62 1/8th (i.e. 11.8x 1/4).
The LS1 has absolutely blew me away in performance.
Also, 243's already finished by AI, I'll be starting a new build thread soon for all my winter "upgrades"...muhahaha.
Old Jan 5, 2013 | 07:59 AM
  #84
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
It took some doing but I eventualy got my main goal for the season with my first 10sec time slip. I smoked the t400 in June and didnt get the car back up and running till late July. Car woudn't 60ft for ****. 1.6-1.7 60ft. times. Seemed like the motor wanted more gear. Tried going from the 28" slick to a 26" drag radial. I had to walk it out to get it to hook with the small drag radial, but when I did I got my best et's with a 10.9et and a 1.51 60ft.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
