!!FIRST!! trip to track friday.. HELP!!
ok, i'm going to the track on friday and need
some help. ok, first i'm going to run about 40psi in the front tires. and about 30-35 in the rear(is this to low??).the only thing i have done to my car is syn-blend motor,trans and rear oil. new wires,MSD coil,plugs, cap,rotor,AFPR,open element w K&N filter
what are some tips for me on friday so i dont
do badly and shame "us" thirdgens?
also what do you think i will run? i think 16.8's
tia,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
1992 Camaro RS 25th anniversary edition Adopted Feb,14 2000
Mods:
14x3 Open element w/ K&N filter, MSD GM blaster Coil and 8.5 SC wires, poly bushings, AFPR, 3-Row Al rad. , 180* t-stat
[This message has been edited by UnderDogRS (edited September 21, 2000).]
tia,
RS
(A.K.A FireBird88)
AOL SN: Zander0710
Mods:
Well if you have a 5 speed I would dump the clutch around 3 grand and if you have an auto load the torque converter to 2500 or so if you can do it without spinning the tires. Then when the lights turn green let go of the brake and since your rpm are already at 2500 you will jump slightly off the line, then put your foot to the floor and never let up. You should probably go to a parking lot and practice this first. Practice gettin into the gas after you let off the brake. Too fast and you will spin to hard, not enough and you will bog that little 305 of yours. GOOD LUCK!!!
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since you're new, just go to have fun. Watch what others are doing first to see where the starting line is etc. When you finally get ready and the car is staged, the 3 yellow lights will come down 1/2 second appart. When you see the last yellow light come on, GO! By the time you and the car react, the light will be green and you should get a good reaction time.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
