Im running a 700r4 thats basically stock except for a shift kit, What is a good rpm to launch at? What rpm should I shift, I am all stock intake except for gutted maf,52mmtb,airfoil,edelbrock headers without a cat and 3" pipe.Oh yeah afpr......From I can tell my motor stops pulling right around 5000...maybe a little more.
umm, stall it as high as it will go (usually around 1300 w/ stock converter) at the line. Adjust your TV cable so it will shift right where it is running out of breath. You want to shift right into your powerband on ever shift, you may have to play with the tv cable some (between my first and second trip to the track, I cut of .4 seconds by screwing with the tv cable)
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
five7kid
close
Conventional wisdom is to run the convertor up to a couple hundred RPMs lower than the stall speed. That will give you a little "flash" when you release & floor it. My stock convertor stalls at about 1700, I'd run it up to 1300 when staged. The '57 stalls at 2200, I run it up to 1800 to launch.
The big boys do this with a rev limiter tied to their trans brake that allows them to floor it while the tree comes down. For instance, set the rev limiter at 4500 for a 5000 stall convertor.
If you don't want to fiddle with your TV cable, you can shift manually. It isn't as consistent, but if you're only looking for some good passes, will do. If you're trying to win at bracket racing, either adjust the TV cable or govenor, or get a ratchet shifter. Try a pass in "D" and see how it does. Then try the next one shifting yourself, etc.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
