Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
new best 1/4 et tell me what you think should i be faster?
Old Nov 6, 2000 | 10:29 AM
bad camaro RS's Avatar
i ran my new best et 13.535 at 104.85
reaction-.887
60ft-1.878
330ft-5.574
1/8-8.666
1000ft-11.318
1/4-13.535
1/4mph-104.85
i ran 13.5 all day with one 13.3 et
last time i ran best at 14.0 with 327 gears what i changed to go from 14.0 to 13.5 was 373 gears and an exhuast cut out hope to go even lower i think with my mph i still got some et to drop what u think? mods in my sig
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Nov 6, 2000 | 02:04 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I think its possible for you to run a little faster, maybe .2 seconds I'm guessing. My best E.T. is a 13.4 @ 100mph with about a 1.85-1.9 60' time. With your mph being higher it seems like you should be running slightly faster than you are but not a whole lot.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Flowmaster 3inch exhaust system, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Nov 6, 2000 | 07:21 PM
NJ SPEEDER's Avatar
what kind of launches are you getting? your 60' is pretty good but i think it is clear from your mph that the car has enough power to go 1.80 or slightly better if you can dead hook.
just a thought.
lata
tim
91 Camaro RS-LO3,Auto.
14.390 @ 94.99mph
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall), 36mm Front 25mm Rear Sway Bars, Eibach Pro Kit Springs, Bilstein Shocks and Struts, Steve Spohn Rear Rig( all rod ends), Poly Front Bushings, Baer Track Kit Front Brakes W/ Baer Disc Rears, 17x9 4th Gen SS Wheels, Ported TB, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
RedLeader289
May 28, 2019 01:47 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Vincent135
Sep 28, 2015 10:50 PM
