Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
BFG drag radials
Old Feb 16, 2001 | 05:51 PM
e-man's Avatar
Car: 89 formula
Engine: 383
BFG drag radials
Do you have to season them before you use them?I have read that you have to do a moderate burnout at dragstrip pressure then let them cool for 24-48 hours to finaly cure.Is this true or can I just go race on them.All so what pressure are you guys running with them.
89 350 TPI,comp cam,edelbrock intake base,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie best ET 14.01@98mph without cam
Old Feb 16, 2001 | 06:24 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
just go race on them, I didnt season them and they worked great for me. DONT get carried away in the burnout box! these tires dont need much smokin- just a quick clean and go.....they last longer that way too.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
Old Feb 16, 2001 | 06:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
http://www.tirerack.com/tires/bfg/bf_drag.jsp
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 16, 2001 | 07:35 PM
q1's Avatar
q1
is it the same with nitto's?
1988 Firbird Formula 350
150hp NX kit, Air Foil
K&N, Jet Stage 2, 8mm wires, MSD 6AL, Trailing Arms, Panard Bar, 3" Ex. with cut out instead of cat. 5" tach.
e.t.= none yet
mph= none yet
Old Feb 17, 2001 | 07:53 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
All I do with my BFg's is a quick spin and straight to the line. As for pressure I run them lower then most people. I run them at 14psi. If I run 16 or aboove I tend to just burn them. By the way I am running 275/50 r15's.
Later
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
NEW for 01
A 408,dart iron eagle heads,street dominator intake, 750 SD,cam 229/239, .497/.520, Also a big hole in the hood.
Shooting for 12's.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
fasteddi
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
