Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
how to stage?????
Old Feb 19, 2001 | 09:31 PM
NJ SPEEDER's Avatar
how to stage?????
i have been doing some expierimenting with my staging. does anyone have a favorite style of getting into the bulbs? my latest favorite is to roll into the pre-stage beems and them hold just enough pressure on the brake peddle to keep the car still and then i tap the gas until the car is just barely into the full stage. this is the easiest way i have found to stage super shallow, and do it consistantly.
what do you guys like?
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Feb 19, 2001 | 11:30 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
thats definatley my favorite way to run a good ET, but I can see it being a bad idea in bracket racing. Launching off the break is the only way to go!
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
Old Feb 19, 2001 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
NJ: I know a lot of racers that do it that way. It just takes lots of practice to get staged in the same spot every time. I've never tryed it myself. I inch up to the prestage light. Once lit I idle up to stage. As soon as the stage light is on I stop. Probably not as acurate as the way you're doing it but that's how I've done it for years. Could also be why I get so many red lights trying to nail the tree. What I really need is a taller front tire. The 165R15 tires are only 25.5" tall. A 28" tall front tire will give a bigger rollout.
Old Feb 20, 2001 | 05:59 PM
NJ SPEEDER's Avatar
either a bigger tire or just drop like 5psi out of the fronts, makes them roll heavier at first. i do it when i am having death ray worries
i used to have a hell of a time with red lights until i learned how to stage really shallow. as far as being consistant one day at the end of last season i went 1.937,1.932,1.933,1.938,1.929(ended up going .007 under,damn!!)
that was the best i ever felt while staging a car
lata
tim
Old Feb 25, 2001 | 06:46 PM
9.0L Firebird's Avatar
most serious bracket guys will run a stage gauge (brake pressure gauge) and stage with 900psi on a line lock and drive the front wheels into the stage lights. bear in mind that if you run a trans brake, the car will sometimes rock a little and may pull out of the stage beams if shallow staged. (automatic red light once both cars are staged)
BBC powered 82 firebird.
Street driven (barely) Best ET no nitrous: 9.42 @142mph , Fogger installed, shooting for low 8s in 2001
Drone358
Dec 10, 2015 08:16 PM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
