Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Cannot get any traction....swap my 3:73s for my original 3:42s?
Old Apr 18, 2001 | 12:37 AM
theformula's Avatar
I was doing a few 0-60 runs on the GTECH today on street tires. I'll put it this way. The car was sideways in 1st , 2nd, and 3rd gear. Actually I didn't really catch until the end of 3rd. Even with all this my 0-60 was still around 5.9. I would of been in the 4s easily,had I had traction. This really made me mad.
Can this be attributed to the 3:73s. Should I go back to my 3:42s. Ok final question. What gear will I be in going through the traps if i put the 3:42s in? 3rd or 4th ?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited April 17, 2001).]
Old Apr 18, 2001 | 08:18 AM
Formula-91's Avatar
What kind of tires are you running? Actually, looking at your mods, it doesn't really matter. You're going to have traction problems with any regular radial. Maybe Nittos or BFG's will work, but that's about it. I'd keep the 3.73s and work on traction. The gains that you'll get with the gears, is worth a little traction difficulties. As for your gear question, I couldn't tell you. I haven't raced with a stick shift in years.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
175 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys.
12.98 @ 106 Natural,
11.83 @ 113 NOS.
Old Apr 18, 2001 | 04:12 PM
Kyle F's Avatar
Try som suspension Mods, Like som sub fram connectors to stiffen the frame. Then Try some LCA and a better pan hard rod. If you are really concerned with just running the 1/4, 90/10 drag shocks will help a lot. Lets face it your going to have trouble hooking up no matter what you do short of tubbing and running slicks. Though a good start is definately some DOT approved BFGs or Nittos.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Apr 18, 2001 | 04:28 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
You will have to shift into 4th gear at the track right before the finish line. 3rd will be topping out right before then with your rear gear set up. As for traction you will have to look into installing a good posi unit, some drag radials, LCA's and a Panhard Rod. The Panhard Rod and LCA's will get rid of any wheel hop.
As for the rear gear, the 3.73's are a good gear. You will want to keep them over the 3.42's to keep the RPM's high for the boost of the supercharger. If you do run the 3.42's you will be in 3rd gear at the end aof the track. You will not have to shift into 4th at all.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
[This message has been edited by Joseph Andres (edited April 18, 2001).]
Old Apr 18, 2001 | 08:17 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
The Gears are not at fault. You have done little to help the suspension out.
Good tires, and Adjustable panhard rod, and boxing the control arms will help her plant.
Subframe connectors will keep the doors opening correctly.
if your still hurtin for traction, put some Lower control arm Lowering brackets on, and some cheaters.
Full slick will shatter the rear sooner rather than later.
Old Apr 18, 2001 | 11:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Apr 19, 2001 | 12:00 AM
theformula's Avatar
True, it does make it very hard. I dont get traction til around 70mph either. I have to learn to just "release" the clutch instead of playing with it during the launch. Thats why I lose it.
Stormshadow GTA
Apr 9, 2001 10:01 PM
theformula
Mar 8, 2001 01:05 PM
