seems slower
Subscribe
Apr 23, 2001 | 02:39 AM
My off the line seems to me to be a little slower now that i replaced my K&N single(stock) snorkel scoop with a paper open element assembly.
Does this make sense or am I out to lunch again?:
Reply 0
Apr 23, 2001 | 07:09 AM
That sounds about right. Instead of pulling cooler outside air with the snorkel scoop and more-efficient K&N filter, you're now sucking in hotter air from the engine compartment through an air filter that can't flow as much air. As a rule of thumb, horsepower is increased 1% for every 10 degrees of air temperature, so if you've increased your intake air temp 50 degrees, leaved lost 5% of your power, which is 10 horsepower from a 200-horse engine.
Greg Westphal
'87 IROC 305TPI/A4
Reply 0
Subscribe
