Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How to launch at the track?
Old Aug 28, 2001 | 11:59 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Whats the best way? Never been... im going to be using street tires, so i wont burnout mearly clean em off with a quick spin. Do it in the water? How exactly does staging work? Launch on the last yellow correct?TIA
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Aug 29, 2001 | 01:06 AM
91'firebrd's Avatar
With street tires stay out of the water. You will see most of the street cars going around the water.
If you have some time before you go pump up the front tires to max pressure. Then find a nice slick level street (or driveway works)
and do some peel outs from a dead stop with different psi's in your rear tires and then check the marks for the best pattern.
If not go with about 20+ psi in the rears.
When you stage you just want to idle up real slow and keep an eye on the tree. When your tires break the first light the top green goes on. At this time you are pre-staged (means nothing) Now after the first green goes on, some people like to just nudge up a fraction of an inch so they just barely break the second light, it will flicker a little first before lighting up. Called a short stage. I like to bump a little closer to the starting line and I nudge a couple of inches more just until the first light goes out. That is called deep staging. My reaction times were better this way.
Take off on the last light or a hair after the second one. You'll look much better to red light then to fall asleep on the line.
"If you ain't moving when the light goes green YOU LOSE"
Shoot for a .600 (which is measures from the last yellow) where .500 is a perfect launch.
Then its real simple just get a perfect reaction and run your dial in time and you will never lose.
Old Aug 29, 2001 | 01:19 AM
Basett_Racing's Avatar
If you're bracket racing, deep staging will help your reaction times for the purpose of being consistent. But if you are ET racing, and trying to get the absolute BEST time you can, then stage as shallow as possible. Deep staging costs you time on the clock, due to the fact that when you stage shallow, you get a little extra rolling start before the clock starts timing.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
Bubbajones_ya
Oct 25, 2015 08:01 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
